  2. Schurkey
    What they liked the best: The brakes. What folks complain about the most on this site: The brakes. I've said it before, I'll say it again: The biggest problem with Gen 1 brakes is not the brakes per se, it's the brake booster.
  3. Today
  4. Yesterday
  5. jmjp5055
    This may not be helpful but check your grounds
  6. This is the formula I used to get the basics for for I wanted....in hindsight it is a bit too stiff, on the highway the springrate is great, car does NOT float, corners reallly well, but where potholes are concerned its a bit harsh. My thinking now that it's been 2 years since I installed it the springrate could be dropped to perhaps 280lbs per inch. The shop owner who fabbed this up did it from the original *high arc* leaf. He used regular *shallow* arc leaves (blank leaves are all arced to a basic curve) to start with, cut them to the length as per the formula, then put each one thru the *hammer* to together match what the ride height the car is at when the glas leaf was in place with the cars weight on it. Of course I had him reduce the arc as the car sits approx 1.7" lower. That means you have to get under the car to measure the curve of the glas leaf when it is under the vehicle weight. Do so from the ends of the leaf to the centre section. I just used a long straight edge, laid it up under the spring ends & took a measurement in the centre. Since I was doing all the *bull work* I had to install, test the ride height, uninstall, go back a couple of times to have him *fine tune* the arc to get all where I wanted it. One has to fab up their own rubber bushings for this.......not hard to do, just takes time cutting them to fit. *Note* to do this the exhaust has to be out of the way.
  7. 94 olds vert
    I never used that feature in either of my first gens.
  8. Psych0matt
    "Automatic shoulder belts"
  9. Would you happen to have the "Specs" the shop used, that could be taken to another shop (local to me in this case)? Thank you!
  10. Last week
  11. 94 olds vert
    When I first saw this I was wondering why this logo was placed on the door handle.
  12. Black92GS
    I saw that as well. From what I have found, the original air date of that episode was the week of October 7th, 1987. Highly likely that those are pre-production Cutlasses that were filmed. The Regal footage is likely a production model since they were the first to go on sale in October. That Regal digital dash footage has to be from a pre-production car though. Either that, or GM made a production change extremely early in the product run to change the tach from red/orange to green.
  13. rcLord510
    Never seen that olds logo on the b pillar like that, and on the SL too
  14. Black92GS
    Gotta love that quality 80s GM fit and finish! And that Regal is very oddly equipped. Bench seat, manual locks and windows, no rear reading lights.....but it has alloy wheels. Then there is this: That cluster must be from a pre-production vehicle, as the tach was never red like that on any of the production ones. My old 88 Regal was a November 87 build, and the tach was green like the rest of the cluster.
  15. Earlier
  16. 94 olds vert
    I had a similar problem on a 2010 GMC sierra. The drivers side door window would only operate when the door was open. I dug into the wiring and found a wire that was nearly broken. I would check wiring and grounds.
  17. Here's me issue. Alternator died and the windows and top quit working along with all the guages. Replaced alternator, guages are back working but the windows now when you turn the key on they will work sometimes and sometimes not in conjunction with the top. Open the door when they are working all is fine till you close the door past the second detent then they quit working. Initially thought it was the circuit breaker and that is assuming the same breaker controls the windows and top. Now thinking the connector for the door to body but I wouldn't think the the wiring for the top would go through that connector, no sure. any body ever experience this?
  18. Black92GS
    Sitting 1995 Regal GS
  19. PairsNPaint
    W-body Install Guides
  20. rcLord510
  21. architect
  22. architect
    Shifting from Parking
  23. architect
  24. 94 olds vert
  25. architect
  26. pwmin
    Actual Dyno CHARTS.
  27. SuperBuick
    3X00 Performance Parts
  28. megavolt380
    TGP Trans
  29. Vegeta
    Actual Dyno CHARTS.
