Sitting 1995 Regal GS
carterluke started following '92 Chevy Lumina 3.1 running rough, under accelerating, slippage? , Sitting 1995 Regal GS and Monte Carlo Z34 5-speed swap HOW-TO
Nothing really. Nothing of that sort is absolutely necessary for a manual swap. All that is necessary is to get rid of the trans stuff so you don't have a constant 6+ error codes and MIL light. Even that isn't really necessary as you can drive fine with no tune changes as long as the PCM is wired to think it's in D at all times. I'm going to leave fueling and timing up to a ZZP remote tune once I switch over to E85, no sense in messing with it now. Other than that, I think the F23 speed sensor is slightly off from the 4T65E as it would read 70 when I was going 73-74, so I adjusted that to match GPS speed. On a side note, I have been looking into extending the clutch master cylinder rod about 1" behind the clutch pedal as the pedal hits the firewall before it's fully pressed, so it might only be 90% released each time which I hope isn't causing extra wear.
This aged well;)
55trucker started following Luminac
primergray started following Which Turbo GP stays and which goes.
Lukeperrin07 replied to GtpKo's topic in Powertrain
What other modifications did you have to make to the tune? Any fueling/timing sorta things? -
GnatGoSplat started following What Conditioner Are You Using on Your Convertible Top Seals?
GnatGoSplat replied to kcac's topic in Cutlass Supreme Convertible
I always used Permatex Die-electric Grease, which is just a silicone grease. I'm guessing whoever used Gummi Pflege doesn't frequent the forum any more. Sounds promising. Couldn't find any actual tests or comparisons. This was the closest thing I could find to a test: https://www.bimmerforums.com/forum/showthread.php?1687676-Annoying-Door-Creaks-Gummi-Pflege-Test -
