  2. Last week
  3. Black92GS
    Sitting 1995 Regal GS
  4. PairsNPaint
    W-body Install Guides
  5. rcLord510
  6. architect
  7. architect
    Shifting from Parking
  8. architect
  9. 94 olds vert
  10. architect
  11. Earlier
  12. pwmin
    Actual Dyno CHARTS.
  13. SuperBuick
    3X00 Performance Parts
  14. megavolt380
    TGP Trans
  15. Vegeta
    Actual Dyno CHARTS.
  16. Nothing really. Nothing of that sort is absolutely necessary for a manual swap. All that is necessary is to get rid of the trans stuff so you don't have a constant 6+ error codes and MIL light. Even that isn't really necessary as you can drive fine with no tune changes as long as the PCM is wired to think it's in D at all times. I'm going to leave fueling and timing up to a ZZP remote tune once I switch over to E85, no sense in messing with it now. Other than that, I think the F23 speed sensor is slightly off from the 4T65E as it would read 70 when I was going 73-74, so I adjusted that to match GPS speed. On a side note, I have been looking into extending the clutch master cylinder rod about 1" behind the clutch pedal as the pedal hits the firewall before it's fully pressed, so it might only be 90% released each time which I hope isn't causing extra wear.
  17. GnatGoSplat
    Luminac
  18. Vegeta
    This aged well;)
  19. 55trucker
    Luminac
  20. pwmin
  21. White93z34
    Luminac
  22. 94 olds vert
    Luminac
  23. Black92GS
  24. White93z34
  25. primergray
    Luminac
    I see it trying to give Firebird III vibes...
  26. Lukeperrin07
    What other modifications did you have to make to the tune? Any fueling/timing sorta things?
  27. I always used Permatex Die-electric Grease, which is just a silicone grease. I'm guessing whoever used Gummi Pflege doesn't frequent the forum any more. Sounds promising. Couldn't find any actual tests or comparisons. This was the closest thing I could find to a test: https://www.bimmerforums.com/forum/showthread.php?1687676-Annoying-Door-Creaks-Gummi-Pflege-Test
  28. GnatGoSplat
