  2. Would you happen to have the "Specs" the shop used, that could be taken to another shop (local to me in this case)? Thank you!
  3. Today
  4. Yesterday
  5. 94 olds vert
    When I first saw this I was wondering why this logo was placed on the door handle.
  6. Black92GS
    I saw that as well. From what I have found, the original air date of that episode was the week of October 7th, 1987. Highly likely that those are pre-production Cutlasses that were filmed. The Regal footage is likely a production model since they were the first to go on sale in October. That Regal digital dash footage has to be from a pre-production car though. Either that, or GM made a production change extremely early in the product run to change the tach from red/orange to green.
  7. rcLord510
    Never seen that olds logo on the b pillar like that, and on the SL too
  8. Black92GS
    Gotta love that quality 80s GM fit and finish! And that Regal is very oddly equipped. Bench seat, manual locks and windows, no rear reading lights.....but it has alloy wheels. Then there is this: That cluster must be from a pre-production vehicle, as the tach was never red like that on any of the production ones. My old 88 Regal was a November 87 build, and the tach was green like the rest of the cluster.
  9. Last week
  10. 94 olds vert
    I had a similar problem on a 2010 GMC sierra. The drivers side door window would only operate when the door was open. I dug into the wiring and found a wire that was nearly broken. I would check wiring and grounds.
  11. Earlier
  12. Here's me issue. Alternator died and the windows and top quit working along with all the guages. Replaced alternator, guages are back working but the windows now when you turn the key on they will work sometimes and sometimes not in conjunction with the top. Open the door when they are working all is fine till you close the door past the second detent then they quit working. Initially thought it was the circuit breaker and that is assuming the same breaker controls the windows and top. Now thinking the connector for the door to body but I wouldn't think the the wiring for the top would go through that connector, no sure. any body ever experience this?
  13. Black92GS
    Sitting 1995 Regal GS
  14. PairsNPaint
    W-body Install Guides
  15. rcLord510
  16. architect
  17. architect
    Shifting from Parking
  18. architect
  19. 94 olds vert
  20. architect
  21. pwmin
    Actual Dyno CHARTS.
  22. SuperBuick
    3X00 Performance Parts
  23. megavolt380
    TGP Trans
  24. Vegeta
    Actual Dyno CHARTS.
  25. Nothing really. Nothing of that sort is absolutely necessary for a manual swap. All that is necessary is to get rid of the trans stuff so you don't have a constant 6+ error codes and MIL light. Even that isn't really necessary as you can drive fine with no tune changes as long as the PCM is wired to think it's in D at all times. I'm going to leave fueling and timing up to a ZZP remote tune once I switch over to E85, no sense in messing with it now. Other than that, I think the F23 speed sensor is slightly off from the 4T65E as it would read 70 when I was going 73-74, so I adjusted that to match GPS speed. On a side note, I have been looking into extending the clutch master cylinder rod about 1" behind the clutch pedal as the pedal hits the firewall before it's fully pressed, so it might only be 90% released each time which I hope isn't causing extra wear.
  26. GnatGoSplat
    Luminac
  27. Vegeta
    This aged well;)
  28. 55trucker
    Luminac
  29. pwmin
