  1. Yesterday
  2. Here's me issue. Alternator died and the windows and top quit working along with all the guages. Replaced alternator, guages are back working but the windows now when you turn the key on they will work sometimes and sometimes not in conjunction with the top. Open the door when they are working all is fine till you close the door past the second detent then they quit working. Initially thought it was the circuit breaker and that is assuming the same breaker controls the windows and top. Now thinking the connector for the door to body but I wouldn't think the the wiring for the top would go through that connector, no sure. any body ever experience this?
  3. Last week
  4. Black92GS
    Sitting 1995 Regal GS
  5. PairsNPaint
    W-body Install Guides
  6. rcLord510
  7. architect
  8. architect
    Shifting from Parking
  9. architect
  10. 94 olds vert
  11. Earlier
  12. architect
  13. pwmin
    Actual Dyno CHARTS.
  14. SuperBuick
    3X00 Performance Parts
  15. megavolt380
    TGP Trans
  16. Vegeta
    Actual Dyno CHARTS.
  17. Nothing really. Nothing of that sort is absolutely necessary for a manual swap. All that is necessary is to get rid of the trans stuff so you don't have a constant 6+ error codes and MIL light. Even that isn't really necessary as you can drive fine with no tune changes as long as the PCM is wired to think it's in D at all times. I'm going to leave fueling and timing up to a ZZP remote tune once I switch over to E85, no sense in messing with it now. Other than that, I think the F23 speed sensor is slightly off from the 4T65E as it would read 70 when I was going 73-74, so I adjusted that to match GPS speed. On a side note, I have been looking into extending the clutch master cylinder rod about 1" behind the clutch pedal as the pedal hits the firewall before it's fully pressed, so it might only be 90% released each time which I hope isn't causing extra wear.
  18. GnatGoSplat
    Luminac
  19. Vegeta
    This aged well;)
  20. 55trucker
    Luminac
  21. pwmin
  22. White93z34
    Luminac
  23. 94 olds vert
    Luminac
  24. Black92GS
  25. White93z34
  26. primergray
    Luminac
    I see it trying to give Firebird III vibes...
  27. Lukeperrin07
    What other modifications did you have to make to the tune? Any fueling/timing sorta things?
  28. I always used Permatex Die-electric Grease, which is just a silicone grease. I'm guessing whoever used Gummi Pflege doesn't frequent the forum any more. Sounds promising. Couldn't find any actual tests or comparisons. This was the closest thing I could find to a test: https://www.bimmerforums.com/forum/showthread.php?1687676-Annoying-Door-Creaks-Gummi-Pflege-Test
