AWeb80 Posted May 5, 2007 Report Share Posted May 5, 2007 THESE P #'S ARE FOR FE3 ONLY BUT THE INSTALL WILL BE THE SAME FOR OTHERS AS WELL. they are Energy suspension P#'s Front inner: 9.5173 Front outer: 9.5159 The bar is 34mm and the bushing is 35mm on the inners and the bar is 22mm and the bushigns are 23mm on the outers...I got the 1mm bigger ones because they are the only size close enough that were greasabel.....on the test ride, there were no problems and uppon installation, everything looked fine. I'm very impressed w/ the quality of the bushings and the mounts. Well worth the ~$32 total that it cost...free shipping from http://www.energysuspensionparts.com/ I had an extra bar so i got it powdercoated grey....I now have my stock 34mm bar FOR SALE if anyone wants it. PM me. and yes, you HAVE to lower the rear subframe to get the bar out....not that hard to do...just takes an extra jack to hold the subframe from falling to the ground. I noticed an imediate difference in steering response and the car wanting to turn in to a turn and not body roll...well worth the investment. Quote Link to comment Share on other sites More sharing options...
97loudcut Posted May 5, 2007 Report Share Posted May 5, 2007 So what is all involved in installing this? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted May 5, 2007 Author Report Share Posted May 5, 2007 So what is all involved in installing this? This took me about 2 hrs...from pulling the car in to pulling it back out...I took my time... for a non 34mm bar car...which yours is jack up th front end, take both wheels off.....then loosen all the mounts..inner and outter put a jack under the rear subframe, take out both subframe bolts 18mm wrench needed. use the jack to lower the subrame....take your bar out, put 34mm in, (notice: the 34mm bar has the ends of the bar turned down slightly....put the ends that are turned town facing the ground) pre lube the poly mounts, put them on the bar, put U-clamps on and tighten all bolts, tighten subframe back up..and have fun. Quote Link to comment Share on other sites More sharing options...
97loudcut Posted May 5, 2007 Report Share Posted May 5, 2007 Hmm..want to sell your old bar to me for cheap? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted May 5, 2007 Author Report Share Posted May 5, 2007 Hmm..want to sell your old bar to me for cheap? yeah...i picked up the one that i got PC'd for $20 at a JY...you want me to PC your bar? i can do $40 shipped to you if you want it pc'd. Quote Link to comment Share on other sites More sharing options...
97loudcut Posted May 5, 2007 Report Share Posted May 5, 2007 No..I don't want it powdercoated, nobody will ever see it. I'll take this to PM's! Quote Link to comment Share on other sites More sharing options...
97loudcut Posted May 5, 2007 Report Share Posted May 5, 2007 This is my next mod! Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted May 5, 2007 Author Report Share Posted May 5, 2007 This is my next mod! good...its worth it. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted May 6, 2007 Report Share Posted May 6, 2007 Matt I thought you already had the 34mm bar? Not to mention Adam's stock bar might be smaller. Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted May 6, 2007 Author Report Share Posted May 6, 2007 Matt I thought you already had the 34mm bar? Not to mention Adam's stock bar might be smaller. its not...it is 34mm....i measured it. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted May 6, 2007 Report Share Posted May 6, 2007 So you replaced it with a powdercoated one thats it? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted May 6, 2007 Author Report Share Posted May 6, 2007 So you replaced it with a powdercoated one thats it? i got another 34mm bar because i wanted to PC it...i then swapped 34mm bars....and put the ES bushings in. all B4U GP's got 34mm front bars... Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted May 6, 2007 Report Share Posted May 6, 2007 looks familiar! PCing looks good Quote Link to comment Share on other sites More sharing options...
Euro Posted May 6, 2007 Report Share Posted May 6, 2007 nice job! And I read the bold print this time Adam....... Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted May 12, 2007 Author Report Share Posted May 12, 2007 nice job! And I read the bold print this time Adam....... sweet. Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted January 25, 2008 Author Report Share Posted January 25, 2008 bump Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted January 25, 2008 Report Share Posted January 25, 2008 bump Why?!?!?!?! Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted January 25, 2008 Author Report Share Posted January 25, 2008 talking to Tom....he wanted info on it why worry about it...you just got a free post out of the deal. Quote Link to comment Share on other sites More sharing options...
Brian P Posted January 25, 2008 Report Share Posted January 25, 2008 Hows it holding up? I went the maintenance free/smoother ride route and got the blue hardass rubber bushings from MOOG. 's right! Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted January 25, 2008 Author Report Share Posted January 25, 2008 great. I love them. NO loss in ride quality.......cars need these from the factory. Quote Link to comment Share on other sites More sharing options...
blackbombshell95 Posted January 26, 2008 Report Share Posted January 26, 2008 I've had mine since fall of 06 and they are holdin up just fine over here. Quote Link to comment Share on other sites More sharing options...
toms92gpse Posted January 27, 2008 Report Share Posted January 27, 2008 Yeah I plan on getting some in a month or 2. Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted January 28, 2008 Report Share Posted January 28, 2008 I need to get these poly bushings for me. Adam, where did you get your front sway bar? Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted January 28, 2008 Author Report Share Posted January 28, 2008 I need to get these poly bushings for me. Adam, where did you get your front sway bar? It was an extra one i got cheap from a yard I still have an extra one....you want it? Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted January 28, 2008 Report Share Posted January 28, 2008 how much for you to part with it? Quote Link to comment Share on other sites More sharing options...
