      9
      5,389
      9,318
  3. rich_e777
      2,651
  4. GnatGoSplat
      9,368
Showing content with the highest reputation on 09/11/2025 in all areas
  1. RareGMFan
    Rear View Mirrors
    rearviewmirrorstore.com is actually my site. I was just checking on visitors for the day, and I saw someone was directed there from w-body.com. I was like.....what?! Then I came here and found this. That's a pretty rare mirror you linked to. As far as I know, they were an exclusive option in the Dodge Stratus, and as you can imagine, there's not a lot of those in the junkyards anymore. It's what I call my "grand daddy of them all" mirror, as it has pretty much every feature other than a back up screen, thus the price. You're actually pretty limited on choices if you want auto-dimming with map lights. Donnelly made them, which were even found in 2nd gen Regals, but Donnelly mirrors are garbage. The auto-dimming gel is pretty much guaranteed to break/leak at some point, and I'm guessing the gel must be acidic or something, because eventually, they start deforming/eating through the plastic housing of the mirror. I have seen this time and time again in the junkyards and in the w-body community. Have helped several GTP owners switch from their Donnelly (no map lights) to that mirror in your last pic. Very easy swap. Another option is the optional 1st gen Sebring convertible mirror. Same mirror was available in the mid-'00s Lincoln Continental and Olds Intrigue GLS, except those had a compass as well. The problem with any of those, as me and Sean have talked about numerous times on this site, is that they require a BCM to kill power to the mirror after X amount of minutes. Otherwise, those mirrors will have a continuous draw on the battery. Enough so that they could kill the battery if you don't start the car after a few days. These are the mirrors I'm talking about: https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights-compass There IS another older option that many don't know about for auto-dimming and map lights. They were an exclusive option for the '90s Chevy Caprice and Buick Roadmaster, so they'd be period correct for your Z34. Only downfall is I believe they use the tension spring mounting instead of a torx screw. I have a few that are still sitting around. This is what they look like:
    Need to know some info about replacing the strut cartridge?
    Take a photo of what you have, generally the aftermarket upper mounts are all near as close to the original design. You mentioned that the holes in the strut tower have been maligned? any portable spring compressor will be a manual item, the safe method is to take the struts to a shop & let them do the replacement on a pneumatic spring compressor that has a cage to protect the techie from danger.
  3. pwmin
    2nd Gen Rear Brakes on a 1/1.5 Gen
    Got the knuckles swapped over and the GXP brakes installed. Going to tackle the e-brake next. Going with a rip-it style handle from an 04-ish J-body and a center console from an 00+ Monte. I have new rear e-brake cables from a 2G, so I'm going to need to figure out how to mate them with the Cavalier one. I know there's a thread somewhere on going to this style e-brake, but I can't find it. Anyone know where it is?
  4. DiscoStudd
    Total dash swap 92 Lumina, what will fit?
    There was another thread that stockgp had detailing his swap. He had to fab up brackets to hold the dash to the firewall (it wasn't "plug-n-play.") I remember him saying the "saginaw" (round) column wouldn't bolt up to the dash support without major modification, either. FWIW, the slope of the windshield on the 95-01 Luminas was steeper than the earlier 1G W's. I remember that due to this, the dash in my old 96 Loomie was a tad bit longer than my Regal's dash. If it were me doing the swap, I'd go with a 94-96 GP dash. It's got the proper slope to the WS, and there are probably more of those in the boneyards anyway. Another bonus of the GP dash is you can easily add the HUD and trip computer (as everyone on this forum and their grandmother have done already ) You could get the GP door panels to work with the Lumina's doors due to the GP's and older Loomies having GM's wonderful "passive restraints" in the doors...
