Showing content with the highest reputation on 10/26/2023 in all areas
  1. Paul GTP
    5 OR 10 W 30 Oil for 3.4 DOHC
    Which Oil is better for the application (not weather releated) I just read article about motor oils on http://www.60degreev6.com It says that 10W30 Oils are much better than 5W30 for the car engines
  2. 91GranSport
    Cutlass Supreme Convertbile Question: Available in 5-Speed?
    Was the Cutlass Supreme Convertible available in a 5-speed? I heard that it was and I also heard that it wasn't. I'd just like to verify that it was. If so, that'd be a pretty sweet ride. BTW: Did all Cutlass Supreme Convertible come with the 3.4 Twin Cam?
  3. White93z34
    PSA: NEW IMGUR Terms of Service effective 15 May 2023
    Remember the Photobucket disaster several years back? Imgur is getting ready to do the same thing next month https://help.imgur.com/hc/en-us/articles/14415587638029 their new rules seem concerned primarily with pornography however this part concerns me: Further Reading: https://www.theautopian.com/imgur-deleting-old-photos/ So needless to say, if you have relied on Imgur to host pictures for forums you would be wise to back them up as soon as possible Thanks!
  4. LukeZ34
    Forum software Upgrade bugs/issues
    Please post any problems you encounter with the forum software in this thread so I can be aware of them. Also, please know that I am working on some back end settings on the forum yet, and we may experience some random downtimes over the next few days. Thanks for your patience over the course of this upgrade!
  5. rich_e777
    Most of my pics are hosted from Imgur, I visit often but will back up just in case. Appreciate the heads up.
  6. runt
    Love that you linked The Autopian! But yes, it's going to be another mass exodus of forum photos missing. In the comment section of that article there is a link for a site: http://www.diyauto.com/ That looks like it could be useful as well.
  7. Imp558
    I would have given you the heart and blown a kiss if Luke haden't changed it, but you got a "thumbsup"
  8. vipmiller803
    Good heavens...
  9. Imp558
    YAY! Thanks Luke! No more awkward blowing kisses, the "thumbsup" is much more comfortable.
  10. Imp558
    Not that I'm a rampant homophobic or anything but at some point after we land on our feet would it be possible to change the "Heart" to something like a "ThumbsUp" when we like content?
  11. patgizz
    uh need some feedback on the 442 project overview...
    i think you're best off with matching engines.
  12. Turbocharged400sbc
    thats cause it's twice the W goodness sorry, it is really long...and i kept it to the minimum...you should see the detailed version
  13. jeremy
    wow that is a long post....I think I will wait until tomorrow to read it
  14. pitzel
    royal purple or amsoil?
    Hmmm, mom's 1990 3800 in her H-body spec's 5W30. My 1992 3.1 spec's 5W30. Any xW-30 oil will have the same properties at high temperature, so manitcor is absolutely right -- it has everything to do with winter starts. Interestingly, a machinist from a local engine rebuilder shop told me over lunch yesterday that in cold climates, synthetic is absolutely imperative for survival of the 3.1L engines over the long term, as he claims that the piston slap problems on these engines largely originate from cold-weather operation with oil that is far too viscous for the engine. I guess, just a theory of a machinst at an engine rebuilding shop (getting him to work on my 1956 Bel-Air's engine soon), but it does sound reasonable.
  15. pitzel
    The '0W' part of '0W30' refers to its SAE viscosity rating with respect to cold starts, while the '30' part refers to its kinematic viscosity while hot at operating temperature. Generally speaking, a 0W30 oil gives you the best of both worlds; the properties of a SAE 30 weight motor oil at engine operating temperatures, as well as fluidity at temperatures of -50C. Many modern 0W30 oils, for example, Esso XD-3 0W30, and made-in-Germany Castrol 0W30 are engineered to actually have significantly better high-temperature properties while retaining their low-temperature properties. Esso XD-3 0W30, for example, has superior high temperature properties to a conventional 10W30 oil, while remaining pour-able down to -50C. They achieve this behaviour through the use of higher-quality fluids. Your fuel economy will not improve with this oil on the highway, all-warmed-up, however, the engine will start much better in the cold and burn substantially less fuel while warming up, thus saving fuel. For anyone in Canada, or in the Northern United States, I whole-heartedely recommend the use of quality synthetic 0W30 oils. For southerners, its unnecessary and a 10W30 grade of Mobil1, Amsoil, or pretty much anything will show equal results.
  16. GnatGoSplat
    I used 5W30 up to 190k on my 89 Cutlass and never had a problem. For the past 2 years I've been using 10W30 in the summer and 5W30 in the winter. Still no problems. The manual states 10W30 is fine in the summer, so that's what I'd use. The reason 10W30 is better: Less viscosity improvers. The base oil viscosity of 5W30 is 5, of 10W30 is 10. It just takes more viscosity improvers to make 5W effective as a 30-weight. Either way, it's no big deal. However, 10W30 is not recommended in climates that go below 0-degrees so if you're expecting some negative temperatures, stick to 5W30.
  17. Jeorge
    My cap says to use 10-30 but I dont have a Dohc, I would say 5-30 in the winter and if you also read your manual it should state for summer 10-30 is fine. and it also askes what type of driving you do....atleast every GM owners manual I have Read says that except mine it states only 10-30 because of the turbo...
  18. cutlassdude96
    The Convrts. did not come with a 5 speed.
  19. rich_e777
    My account was deleted a few days ago, still waiting for a reply as to why.
