      11
      5,389
  2. White93z34
      10,801
  3. Amanita
      366
      9,318
Showing content with the highest reputation on 12/18/2022 in all areas
  1. 94CSC
    Horn pad/airbag CSC
    Thanks for this. The way you’ve described removing it seems fairly simple. I’ll give it a try.
    Horn pad/airbag CSC
    I've been told there is a felt material behind the horn pad touch section behind the airbag cover. This felt material acts as a barrier so that the horn doesn't go off unintentionally. When this material deteriorates with time, the horn will either go off constantly or intermittently or when it's not wanted or needed to go off. I don't have an airbag optioned Cutlass but I would start by looking at the back of the steering wheel and seeing if there are screws. If so, those screws once removed, you should be able to pull the airbag out of the steering wheel. I would disconnect the battery first and wait a while before messing with it though. There will probably be some wires that you'll need to unhook once the airbag is freed from the wheel. Once inside, you should be able to figure out what needs to come off, etc. If that felt material is in bad shape or deteriorated, not sure what would be the best material to replace it with. Like I said, If that material is in bad shape, it will give constant ground or power or whatever and cause the horn to honk constantly or intermittently.
    End of a one off
    Thank you for this! According to Compnine, it's a 1 of 1 car. Not surprising.
  4. White93z34
    End of a one off
    there we go According to the file data these are from 2006
  5. White93z34
    Jeffs Rebuilt Crossover Pipes?????
    Jeff's been MIA for probably longer then he ever was here at this point in time. There was another fellow doing them, however he's long out of the game. However he sold his tooling/jig to @GOT2B GM who I know is still around, he's not on the forum much these days but I sent him a text, maybe he'll jump on. I think he has a Pinned thread in for sale about these.
