  1. Imp558
    Imp558
      9
      6,001
  2. MemphisMan
    MemphisMan
      1,553
      5,380
  4. Z34Luminasty
    Z34Luminasty
      45
Showing content with the highest reputation on 12/26/2018 in all areas
  1. Z34Luminasty
    Replacing a shift boot.
    It’s okay! I mess up stuff all the time! It’s not a big deal at all .
    So I was wrong, sorry guys. I was just assuming and glad MemphisMan chimed in. Good catch and I learned something new! Yes, I made the mistake thinking the shift boots are all the same and I did use the number from my Cutlass parts catalog, my bad.
  3. Z34Luminasty
    Definitely way different than mine. Way too small. I will be having one reupholstered soon to match.
  4. MemphisMan
    Pulling this comment to this thread...I'm thinking the shift boots were different between the 5 speed W-bodys, I know the shift knobs are. jiggity, I think you got the above part number from the Cutlass Supreme parts catalog, correct? Here is the shift boot and knob from my '91 Cutlass Supreme, which is totally different. I've seen a lot of CSs with the same boot and knob as I have. I've also seen a lot of boots on Luminas that all look the same, and are different from the Cutlass ones. I'm going to pull my boot off and have one recreated by a local upholstery shop. Mine is torn on the front and back.
  5. Z34Luminasty
    Hello all!
    ManicMechanic does it again! "For the VIN: 2 - manufactured in Canada G - General Motors 1 - Chevrolet WP - Lumina Z34 14 - coupe X - 3.4 DOHC 4 - check digit (anti-theft measure) N - 1992 9 - Built in Oshawa, Ontario 190412 - sequential order number Your Lumina is 1 of 136 white/gray 5 speed Z34s. It was apparently a California car at one time as it has CA emissions. Breaking it down further, it is 1 of 3 Z34 5 speeds in white with gray, Bose and CA emissions. Here is a list of the options and build date. Report for... 2G1WP14X4N9190412 Vehicle: LUMINA 2 DR Year: 1992 Build Date: 1992-01-15 Found 33,490 vehicles matching that year and model in our database. RPO Description Matches UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3) 28,993 UQ4 SPEAKER SYSTEM,BOSE 4-SPEAKER,INCLUDES AMPLIFIER BOSE SPKR SYS(UQ4) 5,267 US6 ANTENNA,FIXED(PAINTED)(RH REAR QUARTER PANEL MOUNTED) FIXED PAINTED ANT(US6) 33,490 UU8 RADIO,AM/FM STEREO,CASSETTE,ETR,DELCO/BOSE,DOLBY,INCLUDES CLOCK CASSETTE STEREO(UU8) 5,267 VG8 LABEL,NOTICE TO BUYER NOTICE TO BUYER LABEL(VG8) 1,201 VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 29,544 V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 33,490 YF5 CALIFORNIA EMISSION CERTIFICATION CALIFORNIA EMIS CERTIFICATION(YF5) 1,201 Z34 CHEVROLET LUMINA Z34(MERCHANDISING OPTION)(1WM27 + Z34 = 1WP27) LUMINA PKG(Z34) 13,016 0FH Unknown 13,016 1AY ORDER MODIFICATION - STOCK 22,805 1SB PACKAGE-OPTION 02 (1SB) 16,028 1SZ PACKAGE OPTION- (1SZ) 33,461 14D TRIM COMBINATION CLOTH, LT GRAY (14D) 9,877 14I INTERIOR TRIM LT GRAY (14I) 18,600 149 SEAT BELT COLOR LT GRAY (149) 18,600 40U EXTERIOR COLOR,PRIMARY,WHITE (40U) 6,901 6PY COMPONENT FRT LH COMPUTER SEL SUP (6PY) SUSP(6PY) 13,016 7PY COMPONENT FRT RH COMPUTER SEL SUP (7PY) SUSP(7PY) 13,016 AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 32,903 AN3 SEAT,FRONT BUCKET,DRIVER,PASSENGER WITH ELECTRONIC BODY SUPPORT CONTROL FRT BKT ST(AN3) 13,016 AP9 NET,CONVENIENCE CONVENIENCE NET(AP9) 31,559 AR4 RESTRAINT SYSTEM,FRONT SEAT,AUTOMATIC,PASSIVE AUTO PSIV RST SYS(AR4) 33,490 AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 30,966 A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 30,609 A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 27,538 B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34) 29,478 B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35) 29,478 B6O DECAL PKG(LT SILVER,DK GRAY)(USED WITH LUMINA Z34) DECAL PKG(B6O) 3,974 B97 ORNAMENTATION,EXTERIOR,LOWER MOLDING ACCENT LWR ACNT MLDG(B97)(EXPORT) 13,016 C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 30,557 C67 AIR CONDITIONER,FRONT,ELECTRONIC CONTROLS A/C FRT ELEC CONT(C67) 33,450 D55 CONSOLE,FRONT COMPARTMENT FLOOR(USED WITH BERETTA GT PKG Z21) F/CMPT FLR CNSL(D55) 26,292 D68 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL(PAINTED) R/CON PAINTED O/S MIR(D68) 27,597 D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80) 29,042 FE3 SUSPENSION SYSTEM(SPECIAL)(LESS STABILIZER SHAFT)(USED WITH TROFEO SPORT COUPE WL3) SPL SUSP(FE3) 13,016 FV0 RATIO-TRANSAXLE FINAL DRIVE 3.67 RATIO 3.67R(FV0) 1,571 IKD TRIM - INTERIOR DESIGN (KD) 13,016 JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9) 30,767 K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 32,972 K68 GENERATOR,105 AMPERE 105 AMP(K68) 13,010 LQ1 ENGINE,GAS,3.4L(3.4X),MFI,OHC,V6,HO,DOHC 3.4X(LQ1) 13,016 MM5 TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION) 5-SPD M/TRANS PROVISIONS(MM5) 1,571 M27 TRANSMISSION,MANUAL 5-SPEED 5-SPD M/TRANS(M27) 1,571 NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 32,353 NC5 EXHAUST SYSTEM,DUAL TAILPIPES(CHROME) DUAL CHROME EXH(NC5) 13,016 NN5 EMISSION SYSTEM,CALIFORNIA OVERRIDE(EXPORT) CALIFORNIA OVERRIDE EMIS(NN5)(EXPORT) 64 NW0 WHEEL,16X6.5(CAST ALUMINUM) AL WHL(NW0) 23,849 N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33) 33,317 N54 STEERING WHEEL,3-SPOKE(SPORT) 3-SPOKE SPORT STRG WHL(N54) 33,490 OSH PLANT CODE-OSHAWA 1 ONT,GM OF CANADA OSHAWA,ONT ASSEMBLY PLANT(OSH) 33,490 QXJ TIRE ALL P225/60R16/N BL R/PE ST TL AL3 97U TIRE(QXJ) 13,016 R8T CONTROL - SALES ITEM NO. 69 14,141 · 136 White/gray Z34 5 speeds. of those just 3 with bose and CA emissions. Of those 3, only 2 like yours had cruise control. · · So it's 1 of 2 1992 5 speeds in white, gray interior, bose, CA emissions and cruise control."
  6. W30olds
    Trunk leaks
    Well the new trunk seal came today and has been installed. Ran the hose over the trunk lid and so far no water. It's suppose to rain the next 2 days here, so that will be a good test to see if it's fixed. The seal is from Metro Supersoft. Part number is TK46-H if anyone wants a new trunk seal. Got it off Amazon for about $18 with free shipping. Dang Vatozone wanted $40 for the same seal. Thanks to Amazon! BTW this seal fits: 88-96 regal 88-96 grand prix 88-97 cutlass 90-94 lumina If anyone needs one. Sent from my SM-G900V using Tapatalk
