  2. 94 olds vert
    2g Grand Prix dash removal?
  3. Today
  4. Black92GS
    Rear View Mirrors
  5. Yesterday
  6. rcLord510
  7. pwmin
    Rear View Mirrors
  8. rich_e777
  9. RareGMFan
    Rear View Mirrors
  10. Black92GS
    Rear View Mirrors
  11. RareGMFan
    Rear View Mirrors
  12. pwmin
    Rear View Mirrors
  13. GtpKo
  14. rcLord510
  15. pwmin
    Rear View Mirrors
  16. Last week
  17. GnatGoSplat
  18. bravad
    W-body Install Guides
  19. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  20. 89-W-Body-Regal
  21. pwmin
    Rear View Mirrors
  22. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  23. White93z34
  24. White93z34
  25. Earlier
  26. pwmin
    Rear View Mirrors
  27. RareGMFan
    Rear View Mirrors
  28. I've driven it, but I haven't really tested out the braking capabilities yet.
  29. How’s it stop?
  30. It's difficult to get a picture that shows both calipers well.
