dropping the rear of cutlass
already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes - Last week
So, the convertible top switch on my '95 has become somewhat stubborn. The top goes down fine, but to put the top back up, I have to exert an inordinate amount of pressure, pushing the left side inward, as well as slightly upward. I have sprayed the switch liberally with contact cleaner more than once, but to little avail. This problem existed when I bought the car in 2018, but contact cleaner solved the problem for several years, until it reoccurred last year. Anyone know where a new switch can be sourced or have any other ideas of how to address it? - Earlier
dw89xj joined the community
ko777 joined the community
Jscott joined the community
Big D joined the community
Why are you trying to ruin a reasonably-good car? -
Don7778 joined the community
Thelegend joined the community
Black92GS replied to GnatGoSplat's topic in Appearance/Car Care
I knew what you meant. ChatGPT might be on to something about contact with another material causing it to happen. Maybe it’s reacting with the foam inside?Maybe the foam inside is of a similar composition to the one in the headliner, and the sagging beginning around the same time as the sweating is more than a coincidence? For things like armrests and headliners, Im assuming GM just sources the materials for their manufacture. For all we know, there are numerous suppliers and it’s luck of the draw as to which one ages better. Another variable is where the cars were built. 1st Gen Regals and Luminas were built in Oshawa. Grand Prixs in Kansas, and the Cutlass in Georgia. If there are local suppliers involved for things like upholstery materials, it probably also stands to reason that there could be differences in the chemical makeup of the materials that will lead to them all aging differently from each other. As for the remote control issue, I’ve dealt with that a number of times. It was almost exclusively in remotes that spent a lot of time “in hand”. Also dealt with it in some very well used cordless phone handsets. I always assumed it was sweat and skin oils that managed to migrate their way in. Maybe the humidity was the main factor all along? -
It's not melting, exactly. More like sweating or seeping. There's not any noticeable loss of the color material, but it feels like someone's painted honey all over it. I've seen a similar phenomenon happen with old remote controls. The buttons will quit working, and when I take it apart, there's some sticky honey-like substance all over that can be cleaned off with alcohol, but it'll come back. In the case of the buttons, it's silicone oil seeping out. For vinyl, I've read it's plasticizer. ChatGPT assessment - plausible explanation, but sometimes AI is just plain wrong so take it with a grain of salt: Humidity hadn't occurred to me. Not sure that it gets too humid in the car though. It's possible they could have changed the material at some point. It would be a lot easier if they did, as replacing it with the newer version might be a good long-term fix. If I think of it during the daytime, I should go see if the 88's arm rests are doing the same thing or not. Speaking of headliners, that's sagging on my 89 now too. Probably started around the same time as the armrests started feeling sticky. I don't suppose there's any way to salvage the headliner? I'm guess aftermarket stuff isn't going to be a perfect match. Other than the sagging, the fabric itself is perfect. Can't imagine how to get all that foam off the backside cleanly though. -
cutlass wheel fitment
As long as you're not looking for it to tuck, that should be no problem. -
jiggity76 replied to GnatGoSplat's topic in Appearance/Car Care
Oh, that's right. I forgot about the guide thing on the earlier cars compared to the later ones. My International is a 91 but due to a deer hit early on in it's life, it has a 88-90 door on it. The seat belt sits differently than the passenger door one. When I get the car repainted, I'm going to add the 91 driver door and fender from MemphisMan's 91 parts car. He was generous enough to give them to me. -
No clue. I do know it had an 87 build date, so it was one of the earliest Ws built and that might have played a factor as well. Maybe GM made a material/supplier change across the board due to reports of the previous material failing and some early ones came through with the older material? Perhaps it’s just luck of the draw? The sun visors in my 89 seemed to be made of the same material as the headliner in my 88, and they didn’t show any signs of failure or sagging when it was scrapped in 2015. The 89 had an aftermarket headliner as it had an ASC sunroof, so I couldn’t compare the 2. My 92 uses what seems like the same material as the 88s headliner, and the backing foam still feels nice and springy and doesn’t feel like it’s degraded. As for the front seat belts, they changed the style and likely the manufacturer of the guide when they moved them lower on the door frame and got rid of that stupid tension release system. I find the 91+ front belts to sit more comfortably than the 88-90. -
i’d go a little smaller of tire because the overall plan is to put airbags on it when the shop gets a spot open, the goal for me is to have the wheels flush with the body the tires slightly in more than the wheels to have a mean ass fitment when the air bags to air out but
