  2. rcLord510
    2g Grand Prix dash removal?
  3. Today
  4. 94 olds vert
  5. Black92GS
    Rear View Mirrors
  6. Yesterday
  7. rcLord510
  8. pwmin
    Rear View Mirrors
  9. rich_e777
  10. RareGMFan
    Rear View Mirrors
  11. Black92GS
    Rear View Mirrors
  12. RareGMFan
    Rear View Mirrors
  13. pwmin
    Rear View Mirrors
  14. GtpKo
  15. rcLord510
  16. pwmin
    Rear View Mirrors
  17. Last week
  18. GnatGoSplat
  19. bravad
    W-body Install Guides
  20. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  21. 89-W-Body-Regal
  22. pwmin
    Rear View Mirrors
  23. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  24. White93z34
  25. White93z34
  26. Earlier
  27. pwmin
    Rear View Mirrors
  28. RareGMFan
    Rear View Mirrors
  29. I've driven it, but I haven't really tested out the braking capabilities yet.
  30. How’s it stop?
