  1. Yesterday
  2. rcLord510
    2g Grand Prix dash removal?
  3. pwmin
    Rear View Mirrors
  4. rich_e777
  5. RareGMFan
    Rear View Mirrors
  6. Black92GS
    Rear View Mirrors
  7. RareGMFan
    Rear View Mirrors
  8. pwmin
    Rear View Mirrors
  9. GtpKo
  10. rcLord510
  11. pwmin
    Rear View Mirrors
  12. Last week
  13. GnatGoSplat
  14. bravad
    W-body Install Guides
  15. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  16. 89-W-Body-Regal
  17. pwmin
    Rear View Mirrors
  18. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  19. White93z34
  20. White93z34
  21. Earlier
  22. pwmin
    Rear View Mirrors
  23. RareGMFan
    Rear View Mirrors
  24. I've driven it, but I haven't really tested out the braking capabilities yet.
  25. How’s it stop?
  26. It's difficult to get a picture that shows both calipers well.
  27. pwmin
    Rear View Mirrors
  28. RareGMFan
    Rear View Mirrors
