  2. pwmin
    Rear View Mirrors
  3. Yesterday
  4. GnatGoSplat
  5. bravad
    W-body Install Guides
  6. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  7. 89-W-Body-Regal
  8. Last week
  9. pwmin
    Rear View Mirrors
  10. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  11. White93z34
  12. White93z34
  13. pwmin
    Rear View Mirrors
  14. RareGMFan
    Rear View Mirrors
  15. I've driven it, but I haven't really tested out the braking capabilities yet.
  16. How’s it stop?
  17. It's difficult to get a picture that shows both calipers well.
  18. pwmin
    Rear View Mirrors
  19. Earlier
  20. RareGMFan
    Rear View Mirrors
  21. pwmin
    Rear View Mirrors
  22. RareGMFan
    Rear View Mirrors
    rearviewmirrorstore.com is actually my site. I was just checking on visitors for the day, and I saw someone was directed there from w-body.com. I was like.....what?! Then I came here and found this. That's a pretty rare mirror you linked to. As far as I know, they were an exclusive option in the Dodge Stratus, and as you can imagine, there's not a lot of those in the junkyards anymore. It's what I call my "grand daddy of them all" mirror, as it has pretty much every feature other than a back up screen, thus the price. You're actually pretty limited on choices if you want auto-dimming with map lights. Donnelly made them, which were even found in 2nd gen Regals, but Donnelly mirrors are garbage. The auto-dimming gel is pretty much guaranteed to break/leak at some point, and I'm guessing the gel must be acidic or something, because eventually, they start deforming/eating through the plastic housing of the mirror. I have seen this time and time again in the junkyards and in the w-body community. Have helped several GTP owners switch from their Donnelly (no map lights) to that mirror in your last pic. Very easy swap. Another option is the optional 1st gen Sebring convertible mirror. Same mirror was available in the mid-'00s Lincoln Continental and Olds Intrigue GLS, except those had a compass as well. The problem with any of those, as me and Sean have talked about numerous times on this site, is that they require a BCM to kill power to the mirror after X amount of minutes. Otherwise, those mirrors will have a continuous draw on the battery. Enough so that they could kill the battery if you don't start the car after a few days. These are the mirrors I'm talking about: https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights https://rearviewmirrorstore.com/products/gentex-auto-dimming-mirror-with-led-map-lights-compass There IS another older option that many don't know about for auto-dimming and map lights. They were an exclusive option for the '90s Chevy Caprice and Buick Roadmaster, so they'd be period correct for your Z34. Only downfall is I believe they use the tension spring mounting instead of a torx screw. I have a few that are still sitting around. This is what they look like:
  23. pwmin
    Rear View Mirrors
  24. pwmin
    Rear View Mirrors
  25. No it does not. But hear this, I was doing some research in the 1988-1993 BUICK REGAL GM PARTS ILLUSTRATION CATALOG. And I seen I have the first design that fits 1988-1989 REGAL only. It’s called a *1 KIT, which comes with the upper strut mount plate, the rubber insulator mount and the upper spring seat with them studs in it. The second design which every W-BODY had was not sold as a kit. i am thinking it’s the spring seat that is only different. The second design allows you to use the tool on the newer regals. Would it be ok to use the 2nd design spring seat and swap it on mine? The plates and rubber insulator mounts on the 2nd design are the same as the 1989s are on the 1st design. It’s just that spring seat that is not allowing me to install the tool down into the tower to remove the cartridge. I don’t understand why the first design would not allow you to use the tool on the BUICK REGAL. Other W-BODY models for 1988-1989 had the second design spring plate which the BUICK REGAL got the second design spring seat in 1990. here’s photos of them (1st Design on 1988-1989 REGALS) (2nd Design 1990-1996 BUICK REGALS)
  26. ok......what you're referring to is the upper spring seat, curious, when you say that your upper spring seat is totally different from what's supposed to be there does it look anything like this?
  27. That’s the insulator. I’m talking about the retainer mount for the top of the strut that has studs in it. Sorry if it wasn’t clear enough. I apologize for that.
  28. Don't know what was installed..... but the upper mount should look like this..........it's a common item
  29. But I can replace the mount if I wanted to with the oem correct? My mount is different trust me. The strut shaft got jammed in the tower and got stuck under the mount. I had trouble so I had to pry it back to the top so the insulator could go back on. Where the oem ones you could use the tool designed by gm so you would not have to remove the strut. If the tool fits with the oem mounts in these videos you just saw I rather get that mount. I will send a photo of mine and compare it with the one in the video.
