  2. Black92GS
    Intermittent A/C!
  3. crazyd
    Intermittent A/C!
  4. Yesterday
  5. I don't recall the space being restricted, but might have to get a breaker bar on there and a BFH (Big F-ing Hammer).
  6. DIY coilovers. There's no other readily available way.
  7. Last week
  8. Black92GS
    Intermittent A/C!
  9. crazyd
    Intermittent A/C!
  10. Black92GS
    Intermittent A/C!
  11. crazyd
    Intermittent A/C!
  12. crazyd
    Intermittent A/C!
  13. Black92GS
    Intermittent A/C!
  14. crazyd
    Intermittent A/C!
  15. Earlier
  16. for shits and giggles i want sparks to fly when it drives it was a $500 car with 160k miles on it lmao i have no need for it besides body parts. i have no need to own a second one but i chose to because that’s what freedom is all about brother
  17. Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
  18. well i can always stretch the tires a little to tuck it more the wheels can’t be wider than the body or it’s going to look terrible
  19. already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes
  20. Hey contact Don Ouvry he’s a member of 5th generation olds cutlass group and Oldsmobile Club of America Don just picked up another 95 convertible among his collection of 5th generation cutlasses so he has parts
  21. So, the convertible top switch on my '95 has become somewhat stubborn. The top goes down fine, but to put the top back up, I have to exert an inordinate amount of pressure, pushing the left side inward, as well as slightly upward. I have sprayed the switch liberally with contact cleaner more than once, but to little avail. This problem existed when I bought the car in 2018, but contact cleaner solved the problem for several years, until it reoccurred last year. Anyone know where a new switch can be sourced or have any other ideas of how to address it?
  22. rich_e777
  23. Well I think this car is having a similar issue to a `91 Firebird right next to it as if the TGP got infected. No crank, can flash code 12 by jumping A and B on the OBD port, no reason to suspect orange data wire damaged itself inside the dash and the flow chart in the FSM concludes to a faulty ECM or PROM. Is there something else I can test or check to rule out a faulty ECM or PROM? I went the replacement route with the Firebird, spent the money on a new ECM and PROM and it still didnt work.
  24. mdpierce8
    91 Grand Prix window motors
  25. How about part # 08686920 2cw204125168370 i have 4 of them in the crate,s cant figure application steve tinley park ill.
  26. hello. I have a 1990 cutlass international and the rear brakes are seized to the rotors. I’m trying to get the caliper bolts loose but they have restricted space. Especially the top bolt. I saw that Gm made a special wrench for that back then. But seeing if everyone else had an issue or could help me. Thanks.
  27. Sodaman1234
    Door Speakers
  28. I have a 1999 Chevy lumina I’m trying to upgrade form already aftermarket 5.25 wanna see about adding 6.5 anyone know what I can do to to do that or have any thing I can buy to help me
  29. rich_e777
