  2. Black92GS
    Rear View Mirrors
  3. Yesterday
  4. rcLord510
    2g Grand Prix dash removal?
  5. pwmin
    Rear View Mirrors
  6. rich_e777
  7. RareGMFan
    Rear View Mirrors
  8. Black92GS
    Rear View Mirrors
  9. RareGMFan
    Rear View Mirrors
  10. pwmin
    Rear View Mirrors
  11. GtpKo
  12. rcLord510
  13. pwmin
    Rear View Mirrors
  14. Last week
  15. GnatGoSplat
  16. bravad
    W-body Install Guides
  17. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  18. 89-W-Body-Regal
  19. pwmin
    Rear View Mirrors
  20. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  21. White93z34
  22. White93z34
  23. Earlier
  24. pwmin
    Rear View Mirrors
  25. RareGMFan
    Rear View Mirrors
  26. I've driven it, but I haven't really tested out the braking capabilities yet.
  27. How’s it stop?
  28. It's difficult to get a picture that shows both calipers well.
  29. pwmin
    Rear View Mirrors
