  2. 94 olds vert
    2g Grand Prix dash removal?
  3. Today
  4. rcLord510
  5. 94 olds vert
  6. Black92GS
    Rear View Mirrors
  7. Yesterday
  8. rcLord510
  9. pwmin
    Rear View Mirrors
  10. rich_e777
  11. RareGMFan
    Rear View Mirrors
  12. Black92GS
    Rear View Mirrors
  13. RareGMFan
    Rear View Mirrors
  14. pwmin
    Rear View Mirrors
  15. GtpKo
  16. rcLord510
  17. pwmin
    Rear View Mirrors
  18. Last week
  19. GnatGoSplat
  20. bravad
    W-body Install Guides
  21. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  22. 89-W-Body-Regal
  23. pwmin
    Rear View Mirrors
  24. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  25. White93z34
  26. White93z34
  27. Earlier
  28. pwmin
    Rear View Mirrors
  29. RareGMFan
    Rear View Mirrors
  30. I've driven it, but I haven't really tested out the braking capabilities yet.
