  1. Yesterday
  2. Last week
  3. Black92GS
    Intermittent A/C!
  4. crazyd
    Intermittent A/C!
  5. Black92GS
    Intermittent A/C!
  6. crazyd
    Intermittent A/C!
  7. crazyd
    Intermittent A/C!
  8. Black92GS
    Intermittent A/C!
  9. crazyd
    Intermittent A/C!
  10. Earlier
  11. for shits and giggles i want sparks to fly when it drives it was a $500 car with 160k miles on it lmao i have no need for it besides body parts. i have no need to own a second one but i chose to because that’s what freedom is all about brother
  12. Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
  13. well i can always stretch the tires a little to tuck it more the wheels can’t be wider than the body or it’s going to look terrible
  14. already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes
  15. Hey contact Don Ouvry he’s a member of 5th generation olds cutlass group and Oldsmobile Club of America Don just picked up another 95 convertible among his collection of 5th generation cutlasses so he has parts
  16. So, the convertible top switch on my '95 has become somewhat stubborn. The top goes down fine, but to put the top back up, I have to exert an inordinate amount of pressure, pushing the left side inward, as well as slightly upward. I have sprayed the switch liberally with contact cleaner more than once, but to little avail. This problem existed when I bought the car in 2018, but contact cleaner solved the problem for several years, until it reoccurred last year. Anyone know where a new switch can be sourced or have any other ideas of how to address it?
  17. rich_e777
  18. Well I think this car is having a similar issue to a `91 Firebird right next to it as if the TGP got infected. No crank, can flash code 12 by jumping A and B on the OBD port, no reason to suspect orange data wire damaged itself inside the dash and the flow chart in the FSM concludes to a faulty ECM or PROM. Is there something else I can test or check to rule out a faulty ECM or PROM? I went the replacement route with the Firebird, spent the money on a new ECM and PROM and it still didnt work.
  19. mdpierce8
    91 Grand Prix window motors
  20. How about part # 08686920 2cw204125168370 i have 4 of them in the crate,s cant figure application steve tinley park ill.
  21. hello. I have a 1990 cutlass international and the rear brakes are seized to the rotors. I’m trying to get the caliper bolts loose but they have restricted space. Especially the top bolt. I saw that Gm made a special wrench for that back then. But seeing if everyone else had an issue or could help me. Thanks.
  22. Sodaman1234
    Door Speakers
  23. I have a 1999 Chevy lumina I’m trying to upgrade form already aftermarket 5.25 wanna see about adding 6.5 anyone know what I can do to to do that or have any thing I can buy to help me
  24. rich_e777
  25. mdpierce8
  26. I moved the coils on my turbo Monte and I was getting a CEL (1530, I think), but it would run and drive fine. Didn't get it figured out and then it decided it didn't want to stay running. I found the power wire to the coil had a break in the connector I used to extend the wire, so I fixed that and now it cranks, but won't start (no spark). The wires test good and the 7x crank sensor as well. We had put a new ICM on, so I went back to the old one and same thing. From what I've gathered, the only things that it could be is power to the coil, the wires to the crank sensor, the crank sensor or the module/coils. If you unplug the 5-wire connector it should still get base timing and start. Any ideas?
  27. IIRC you can reuse the fabric but when re-applying you start from the center and work your way out because its stretched. I recall an old episode of something car.TV where they redid one. Used razor blades to scrap the old foam off, glued a new sheet on and trimmed it. Then used spray adhesive to put the fabric back on and with a roller went from the center out to the edges. It looked doable but I would want to use a new piece of fabric or even vinyl. You need to remove the front seats and center console to get enough clearance to get the board out then back in. Then you will need an assistant or build a contraption to hold the board in place until all the mounting points are screwed off/on other wise you`ll crease the board if one end drops. I held it up with my head and a large thin hardback book to spread the contact point out, and with knee pads I was able to get the sun visors and rear hooks back in that hold it up.
  28. Why are you trying to ruin a reasonably-good car?
