dropping the rear of cutlass
Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle? - Earlier
already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes -
dw89xj joined the community
ko777 joined the community
Jscott joined the community
Big D joined the community
Why are you trying to ruin a reasonably-good car? -
