92Lumi reacted to a post in a topic: LQ1 3.4L DOHC V6 Timing Belt Change
92Lumi reacted to a post in a topic: Powertrain swap in 91 Lumina
92Lumi reacted to a post in a topic: LS4 from 2006 Impala SS 92 Lumina Z34...will it fit???
dropping the rear of cutlass
already have a project cutlass with air suspension and i don’t need two headaches having a good ole shitbox is good sometimes -
dw89xj joined the community
ko777 joined the community
Jscott joined the community
Big D joined the community
Why are you trying to ruin a reasonably-good car?
