  2. jiggity76
    Cooling fan questions
  3. Today
  4. 55trucker
  5. Megavolt-380
  6. sclark
    Replacement Top Seals
  7. Yesterday
  8. Yep, I've also read it's not reversible, which is pretty annoying to have to clean it with alcohol all the time. It's been out of the sun for the last 5-years, but the damage is already done. Also gets pretty hot in the garage and I'm sure that doesn't help. Only permanent-ish solution I could really think of is to have it wrapped in color-matched leather. Might look nice if professionally done. Only thing is if leather needs to be glued down, it wouldn't stick for long if the vinyl underneath keeps sweating. Maybe it would need to have the vinyl stripped off, then built up and sculpted with some other material to the right shape so that part can be leather-wrapped. Sounds like very high cost. Other parts of the car would need attention before I go to that extent to fix it though.
  9. Last week
  10. This is something that I remember hearing about years ago about when modern day cars would age. The plastics would decay and the first stage is when they get sticky. Then over time that stops and the plastics dry out and get hard and start to crack. I don't think it's possible to reverse this process once it get started. I know it's a big issue on foreign cars that are around 20 years old. They always seem to get the sticky buttons. It is just going to keep happening. The best thing would be to clean, protect and keep it out of the sun to reduce the decay rate. Unfortunately these cars don't have a lot of aftermarket support, so getting new interior pieces isn't really an option. Buying a used one is likely going to have the same issue. Pretty impressive the car went 30 years without having that problem. Lasted much longer than most.
  11. It's a bit of a bummer, my 89 Cutlass door armrests are very gooey and sticky due to sweating plasticizer. It's been going on the past few years. I've read this is how vinyl decomposes, and it won't stop until the vinyl becomes hard, brittle, and cracks. I've been cleaning it off with isopropyl alcohol in the meantime, but it's just temporary. Going to try cleaning it again, then putting 303 Aerospace Protectant on it. Anyone else have this problem and found a solution that works?
  12. This is all I could really find for free. https://charm.li/Oldsmobile/1992/Cutlass Supreme FWD V6-189 3.1L/Repair and Diagnosis/Heating and Air Conditioning/Evaporator Core/Service and Repair/ Although I 100% agree that you should get the genuine GM service manual. Well worth the $7.50+shipping. https://www.ebay.com/itm/235434976664
  13. Wanted to update this topic. The lubricate spray appears to have solved the issue and is holding up the conditions it is being exposed to. Thanks to all who have helped!
  14. Does anyone have a picture of where they cut the front spring, or a picture of the spring after cutting?
  15. Yeah, one could do that, or......pick up a set of these
  16. What is the GM part number for the O-ring? Find out, and cross it to something in the aftermarket if the GM part is discontinued.
  17. The Genuine GM service manual set for your vehicle is your friend. First Guess: If you can get in there from the HVAC blower-motor area with a vacuum, and perhaps compressed-air on a long, thin nozzle, you don't have to take the evaporator OUT. Then the A/C system doesn't have to be discharged, desiccant pouch replaced, (new accumulator) system evacuated, and re-charged. IF (big IF) the system is still leak-free, you aren't disturbing any of the seals. OTOH, it's a pain in the tuckus to REALLY clean an evaporator. But it's probably even worse to replace one. Good luck. If you do have to open the refrigerant system, be sure to replace the desiccant, and be sure to replace EVERY O-RING IN THE SYSTEM. And have a careful look at the condenser for leaks and folded-over air fins. Might be a good idea to just upgrade the condenser while the system is apart. Remove and examine the orifice tube--any debris, and you need a compressor, too. Flush every part you intend to re-use (except the compressor) and use the correct oil for the refrigerant you're using--in '92, that'd be R12 as OEM. So again, "good luck".
  18. Hello if this has been posted already it would be greatly appreciate if someone can share a link to how to replace the ac evaporator in my 92 . It’s so packed full of junk it hardly blows any air and blew out the seal at the bottom so clearly I need to remove and clean it out. &nbsp
  19. I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated
  20. Earlier
  21. rich_e777
    convertible carpeting
  22. I will remember not to use the impact on the new ones and use the socket. I will have to torque to specs anyhow the nut on top. I try to use the Torx and socket on the old struts but it was so dirty I wouldn’t come loose and stripped the thread. So I used an impact to remove the nut.
  23. Mike1998Lumina
    Brake Line Size
  24. The #50 torx tip is needed to stop the piston shaft from rotating in the shock housing while undoing & tightening up the the retaining nut. As I stated earlier some aftermarket shocks no longer make use of a torx design for the socket interface at the top end of the piston shaft. Spinning the piston shaft with an impact gun is not desirable. Doing so with the outgoing shock is alright but no so with the new shock.
  25. Then you are looking for an OTC 7568A kit. Where are you going to find just the tool you need?
  26. So seeing the photos you posted that’s all I need those tools? I wouldn’t need the whole kit.
  27. It would be cheaper I think just to get the tools I need. I don’t really need the Torx socket or that other socket it goes with it because I can remove the nut with an impact and I have that long strut spreader cylinder tool.
  28. The strut kit i have says OEM # 27034. This is the same kit that Autozone used to rent. I see ebay has the same kit listed as T&E Tools AT185.
  29. Which kit is this? Any brand names I can buy with everything I need? One kit i bought was kent moore that was originally used by GM Dealers when these cars were new. The tool service kit was missing tools so I had to buy some tools extra that weren't in the kit. When I didn't have luck removing the strut cartridges I sent it back.
  30. Which kit was that in and is that the nut from the cartridge that long tool fits over?
