  1. Last week
  2. rcLord510
    2g Grand Prix dash removal?
  3. 94 olds vert
  4. rich_e777
  5. rcLord510
  6. 94 olds vert
  7. rcLord510
  8. 94 olds vert
  9. Black92GS
    Rear View Mirrors
  10. rcLord510
  11. pwmin
    Rear View Mirrors
  12. rich_e777
  13. RareGMFan
    Rear View Mirrors
  14. Black92GS
    Rear View Mirrors
  15. RareGMFan
    Rear View Mirrors
  16. pwmin
    Rear View Mirrors
  17. GtpKo
  18. rcLord510
  19. pwmin
    Rear View Mirrors
  20. GnatGoSplat
  21. bravad
    W-body Install Guides
  22. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  23. 89-W-Body-Regal
  24. pwmin
    Rear View Mirrors
  25. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  26. White93z34
