  2. rcLord510
    2g Grand Prix dash removal?
  3. Today
  4. 94 olds vert
  5. rich_e777
  6. rcLord510
  7. 94 olds vert
  8. rcLord510
  9. 94 olds vert
  10. Black92GS
    Rear View Mirrors
  11. Yesterday
  12. rcLord510
  13. pwmin
    Rear View Mirrors
  14. rich_e777
  15. RareGMFan
    Rear View Mirrors
  16. Black92GS
    Rear View Mirrors
  17. RareGMFan
    Rear View Mirrors
  18. pwmin
    Rear View Mirrors
  19. GtpKo
  20. rcLord510
  21. pwmin
    Rear View Mirrors
  22. Last week
  23. GnatGoSplat
  24. bravad
    W-body Install Guides
  25. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  26. 89-W-Body-Regal
  27. pwmin
    Rear View Mirrors
  28. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  29. White93z34
