Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years. - Yesterday
Did it make it to 200k? - Earlier
