  2. 94 olds vert
    2g Grand Prix dash removal?
  3. Black92GS
    Rear View Mirrors
  4. Yesterday
  5. rcLord510
  6. pwmin
    Rear View Mirrors
  7. rich_e777
  8. RareGMFan
    Rear View Mirrors
  9. Black92GS
    Rear View Mirrors
  10. RareGMFan
    Rear View Mirrors
  11. pwmin
    Rear View Mirrors
  12. GtpKo
  13. rcLord510
  14. pwmin
    Rear View Mirrors
  15. Last week
  16. GnatGoSplat
  17. bravad
    W-body Install Guides
  18. Starting this journey now, and any info you might have would be great. Going to YouTube it all
  19. 89-W-Body-Regal
  20. pwmin
    Rear View Mirrors
  21. The 1995 factory manual said to use silicone grease (GM 12345579 or equivalent) on weather-stripping. If you have tried something other than silicone grease, how is it working for you? An older post mentioned Gummi Pflege instead of silicone grease. I am getting ready to do maintenance on my convertible top, and was just going to use silicone grease again, but am interested in hearing what products people are currently using.
  22. White93z34
  23. White93z34
  24. Earlier
  25. pwmin
    Rear View Mirrors
  26. RareGMFan
    Rear View Mirrors
  27. I've driven it, but I haven't really tested out the braking capabilities yet.
  28. How’s it stop?
  29. It's difficult to get a picture that shows both calipers well.
