iTurbo Posted July 4, 2012 Report Share Posted July 4, 2012 So I'm thinking of getting some 1.9 rockers for the Regal. I had thought about getting a cam instead, or maybe intercooling the car, or getting some SD headers on eBay, but I have too much on my plate right now as far as car projects so I'm considering getting some rockers instead because they would be pretty easy to install in an afternoon. I saw the 1.9 rockers on ZZP and the W-body Store, but then I noticed that, for a little more $$$, I can get the Yella Terra roller rockers/pushrods instead. Either way I will get upgraded valve springs. What do you guys think? As far as going with a cam or intercooling or headers, I will probably just wait till next year and just pull the motor out to do that stuff if funds allow. Right now I'm primarily interested in pounding the Caliber SRT-4 from a roll, but considering the insane top end that car has, I'm a little skeptical that it will happen even with the current mods + 1.9 rockers. Current mods: ZZP 3" cat-less downpipe ZZP 1.0 PCM ZZP modular pulley system with 3.4" pulley ZZP cast aluminum trans pan + new filter + Dex VI fluid JMB 4" fender well intake Racetronix fuel pump rewire + relay new Delphi fuel pump module complete set of polyurethane engine mounts (I think my bro got 'em from W-body store) Autolite 104 plugs Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 4, 2012 Report Share Posted July 4, 2012 (edited) You dont need new springs with the modded 1.9's. Terry will say you dont either with the 1.9 rollers, but everywhere else says to. If you get new springs, Id recommend 105# for the least wear on the timing chain and tensioner, and make sure to get the new retainers too so the install height is correct. Edited July 4, 2012 by Andrew Quote Link to comment Share on other sites More sharing options...
terryk2003 Posted July 4, 2012 Report Share Posted July 4, 2012 (edited) I hope I'm not the Terry you are referring to as I'm running 105# springs with my 1.9RRs. Im not positive 105's are necessary (iirc, I was told I could have used the lighter aftermarket springs. Don't remember the # though), but I was planning on going to a aftermarket cam later on which is why I did the 105's. Edited July 4, 2012 by terryk2003 Quote Link to comment Share on other sites More sharing options...
95 vert Posted July 4, 2012 Report Share Posted July 4, 2012 I just installed a set of the Yella Terra's for a buddy of mine. I also modified a GP short stack intercooler to fit his 96 Cutlass coupe with a 3.25 pulley. His car runs damn good but won't outrun my Vert with a S1X cam. Obviously the rockers would be less work but the cam would be more bang for your buck. Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted July 4, 2012 Report Share Posted July 4, 2012 I'd just suck it up and do the cam. I ran 14.3x with a 3" DP, ported mani's, 104's, Walbro pump, and 3.4" pulley. After only swapping out the cam with a S1x and injectors, I ran a 13.58 as my best time. HUGE difference and I think its way worth the extra time and money. Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 4, 2012 Report Share Posted July 4, 2012 I hope I'm not the Terry you are referring to as I'm running 105# springs with my 1.9RRs. Im not positive 105's are necessary (iirc, I was told I could have used the lighter aftermarket springs. Don't remember the # though), but I was planning on going to a aftermarket cam later on which is why I did the 105's. oh i thought it was you that said that! my bad. there are LS6 90# springs, but IIRC they have a higher spring rate, so at full lift, they take more pressure than the 105s at full lift, which wears out the timing system faster. Quote Link to comment Share on other sites More sharing options...
pshojo Posted July 4, 2012 Report Share Posted July 4, 2012 I don't have super charged engine, but i did buy rockers for my L26. I'm wondering if I should've gone with cam. This is only for daily driver and this is my first shot at modding 3800's. ; Quote Link to comment Share on other sites More sharing options...
pshojo Posted July 4, 2012 Report Share Posted July 4, 2012 Does the cam help bottom end torque or take off? Or does cam mostly help upper/mid range? I've been modding my dad's :GSE.. He wants better torque at stop lights, he used to have Caddy with 4.5L. And he wants the feeling of having throttle response from stop. Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted July 4, 2012 Report Share Posted July 4, 2012 Yeah a cam boosts performance through the whole powerband. Rockers will mainly help with the top of the powerband only. When you do other mods you will see better performance afterwards with a cam as well. Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 5, 2012 Report Share Posted July 5, 2012 well, it depends which cam you get. Some are designed for top end HP. Rockers are good for beginners, much easier to install. I never thought any 3800 lacked torque off the line. Maybe the Buicks have strict torque management? I know that drive by wire setup can be a little weird at first too, i dont like it. Theres a little delay. Quote Link to comment Share on other sites More sharing options...
bkaab Posted July 5, 2012 Report Share Posted July 5, 2012 (edited) Ya don't need to change the springs unless ya planned on raising shift points. There really is no need for 105#'s 90# LS springs will be just fine. Usually a bigger cam will give you a low end loss in a NA car but with a supercharger its not really effected. The big thing that makes a aftermarket cam better then rockers is it not only adds lift but duration. Stock cam 3800 lift w/stock rockers: .413/.413 Stock cam 3800 lift w/1.9 rockers: .490/.490 Edited July 5, 2012 by bkaab Quote Link to comment Share on other sites More sharing options...
iTurbo Posted July 5, 2012 Author Report Share Posted July 5, 2012 Thanks for the input guys. I am going to hold out for the cam and some other upgrades later on. Going to spend the money on a good scan gauge instead. Or hopefully I can finally find an iOS app that will let me monitor KR and use my Kiwi Wifi. Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted July 6, 2012 Report Share Posted July 6, 2012 Good call man Quote Link to comment Share on other sites More sharing options...
