Showing content with the highest reputation on 03/17/2026 in all areas
  1. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
    It's that time. The oil leak in the rear main seal of my 1994 Cutlass Supreme SL with the 3.4L motor has gotten so bad that it needs to come out for repairs. In addition to this being in need of replacement, I am going to have the oil pan gasket replaced as well, along with the 3 coils and the alternator while the motor is out of the car. In addition to that, is there anything else anyone can think of that should be replaced while the motor is out, as this would be a golden opportunity to get it done. The engine compartment will also be degreased to clean up the big mess this leak has been making. It does not need a timing belt, water pump, or any intake manifold work as this was all done 5 years and 10,000 miles ago and no issues here.
  2. bluecalais79
    UPDATE - I believe I may have found a shop with a mechanic having the experience to have worked on these motors that will do the job. My first hunch was to go to a Chevy dealership as the Lumina had these motors as well, those Z-34's you almost never see (?). As soon as they found out I was in no rush to get the car back, they were more open to the idea of working on it. I guess they thought I wanted it done yesterday. Not the case, anytime between now and July 22 will do........ Stay tuned
  3. My 89 Grand Prix was not in use for many years, the radio degraded in that time. It started to give a lot of pops and bangs. So much it seems to have blown a front speaker in the few moments it has been turned on. The speaker is an easy fix, just remove the dash pad and screw a new one in (16054362 is replaced by 15173233 and can be easily found). My system is a 4 speaker with Remote control head 16075882, the optional Cassette+equalizer 16050912 and steering wheel controls. The amp and receiver (16072780) which is located above the glovebox is the one that typically causes issues. I found the documentation here on the forum, unfortunatley the link for the amp doesn't work anymore: But even better than documentation, I found a common cause and fix for the pops and bangs: I tried exactly this procedure: https://reattaowner.com/roj/component/content/article?id=198:radio-capacitor-replacement-instructions. The 6 green capacitors were indeed shot. I found d4x5mm (not d5x5mm), 1uF, 50V, 105°C replacement capacitors at RS and had a specialist to put them in. The radio now works well, only some very minor pops are still noticable when the volume is turned to 0. I am very happy with the result and recommend this fix. However, I did notice now that my FM tuner apparently only goes up to 104.05MHz... Scanning, or manual tuning to get past 104 make it jump to the bottom of the frequency band again. I wonder if anyone else had a similar issue or fix for this?
  4. sbrent10
    92 Lumina rear caliper removal
    Hey Iv'e browsed around here for a long time, but just actually joined for much needed help. My rear pads are completely gone and have damagd my rotors pretty bad. I went to replace the pads and rotor but noticed the rear calipers have the e-brake attached to it. How do i remove the caliper with the e-brake in the rear? I think i can remove the cable but the actually ebrake unit itself in the the way of the caliper bolts. any help is appreciated, thanks!
  5. Schurkey
    Yup. That'll do it. Not the best/most efficient method--but that'll work. Pistons definitely twist back in--unless you remove the one nut and one washer, and pull the eBrake cable bracket. Pushing the piston STRAIGHT in with a c-clamp is a thousand times easier than spinning it back in, and there's no special tool needed. Instead of the huge friction from the large piston seal, you have very little friction from the small O-ring that seals the small threaded post that the e-brake cable bracket is secured to. It could not be easier--except to have a caliper that doesn't have the e-brake mechanism. All four of my rear calipers have had the pistons pushed straight back in, one car has been done two--three times as the pads have worn out. E-brakes and service brakes still work just fine. This does NOT destroy the calipers IF (big IF) you REMOVE THE NUT, WASHER, and BRACKET. No promises on this working on the newer-style calipers, but it certainly works on the first-gen style.
  6. Schurkey
    That is the official procedure. My way is far faster and easier.
  7. RobertISaar
    i did the "remove backside stuff" method before.... i think i did something wrong though, because then it would never seal back there again. or maybe the caliper itself was already failing when i got to it. either way, i ended up replacing with the 94-up setup due to that.
  8. Schurkey
    '92? Caliper piston does NOT need to be TURNED back in. In fact, that's the most-difficult possible way to retract it. Remove one nut and one washer from back side of caliper--remove the little bracket that the park brake cable attaches to. Remove caliper from rotor. Secure so it doesn't hang from the brake hose. I pinch the rubber brake hose with a needle-nose vice grip or the special hose-pinching tools. (Can't do that with aftermarket steel braid-over-Teflon liner brake hoses!) Open the brake bleeder valve on that caliper. Push caliper piston back in with a C-clamp. The spinning is done by the shaft that the nut, washer, and bracket were attached to, not the piston. Brake fluid squirts out bleeder valve, might want to use a length of vacuum hose on the bleeder nipple to direct the fluid into a drain pan. DO NOT allow the old dirty brake fluid to push backwards through the system so that it contaminates the ABS hardware. Remember that the caliper is adjusted by REGULARLY USING THE PARK BRAKE, so if you go months at a time without setting the park brake, expect caliper problems.
