  1. Black92GS
    Black92GS
      146
    55trucker
      2,237
      2,648
Showing content with the highest reputation on 02/19/2026 in all areas
  1. Black92GS
    Should I go back to stock?
    That's how I'm looking at it. I wouldn't have not bought the Regal, or insisted on paying any less for it if there was a disconnected and neatly stored amp wire running back to the trunk, everything else being equal. My thought is that the target buyer for that car is the type of person to be a member here, and is likely to be relatively well versed in them to where something like that wouldn't make a difference in either case. It's not a super low mileage museum piece where I feel something like that would make a difference. If anything, that car being "The Car" of these forums makes it more desirable, but that's just me.
  2. Black92GS
    If it were me I'd pull it... but I also wouldn't worry too much about seeing it neatly tied up and disconnected at both ends if I were a buyer. It was the style at the time to run aftermarket stereos in nearly everything, so I consider it to be remanent of a former, period correct modification.
  3. bluecalais79
    Agree. As I always say, your car, your call. Do it for what you want rather than what the next owner may (or may not) want. I myself am after the total factory look, but if I can hide something that will otherwise give it the factory look, that's good news. I've replaced my Retrosound rear speakers with another aftermarket brand set that fits into the hole and under the grille sufficiently. They get hit by the sun with that huge rear window so I avoided a paper coned speaker with something more durable. I'm loathing replacing the door panel speakers, but as soon as II find that set of correct NOS ones I've got in storage somewhere, I've got a job to do............
  4. 55trucker
    Rust free rotors?
    The thought here was that you don't drive your W's in the winter.
  5. rich_e777
    Rust free rotors?
    Unfortunately its the opposite of that pre-conceived notion of the south, they spread that stuff anytime the temp gets close to 32F overnight and its wet out. Ive researched a bit more into the options available and will go with the coated PowerStop kit from RA. Just trying to generate some conversation I guess...
  6. Black92GS
    Rust free rotors?
    I mean...those uncoated rotors often flash rust after a single wash and start looking pretty shabby in very short order, especially if the car has the 5 spokes or some other wheel that shows much of the brakes. Definitely won't need protection from salt, but as the coated ones do decently well against that, I can see them lasting forever on a southern car.
  7. Black92GS
    Rust free rotors?
    Not on my W's...but I use them on my dailies. I prefer to use the rotors with the black coated hat/edge vs the silver coated ones, as I find they hold up better. They seem to hold up relatively well, even throughout the winter. In all honesty though, if your current rotors are still good you could always hit them with a bit of black spray paint. I quickly hit the rear drums of my truck over 5 years ago without any real prep work, and those have held up better than some of the coated rotors i've run.
