Showing content with the highest reputation on 02/02/2026 in all areas
    1988 MW with John Davis discussing the GM10 coupes
  2. GnatGoSplat
    1992 Cutlass Supreme Coupe Door Speakers
    I bought some decades ago to do the same thing, but never got around to it. I was going to try to mod them for 6.5" speakers and needed a plan for how to mod the buckets, but in the modern day, it would make more sense to 3D print some custom ones rather than mod the OEM ones as I wanted to use the OEM grilles which are flat against the trim panel. I can't find them at the moment or I'd snap a pic. As for prewired, my 89 wasn't prewired, but different years might do things differently.
  3. GnatGoSplat
    I think the mounts will fit the doors, but I don't know that they'll fit under the door panels. 95-96 used 5.25" in these angled enclosure pod things that stick out quite a bit while 88-92 used 4x6's on a flat plate.
  4. GranPrix
    RPO code for 3.29 gear ratio in olds intrigue.
    So my hunt begins for an intrigue with the 3.5, I'm looking specifically for a GL or GLS with the 3.29 gear ratio. Anyone know the RPO code for that to help me in my searches? Google and rpocode.com aren't helping me
  5. Raffaelli
    Draining Gas Tank - 95 Regal
    Does the pump run? If it does, unhook a fuel line under the hood and jump the fuel pump relay.
  6. 55trucker
    3.8sc swap into 94 Oldsmobile cutlass Supreme convertible
    The *actuator* was discontinued approx 20 years ago.......finding an NOS piece would be a challenge. The item IS serviceable..........
  7. Schurkey
    What they liked the best: The brakes. What folks complain about the most on this site: The brakes. I've said it before, I'll say it again: The biggest problem with Gen 1 brakes is not the brakes per se, it's the brake booster.
  8. Psych0matt
    "Automatic shoulder belts"
  9. Black92GS
    Gotta love that quality 80s GM fit and finish! And that Regal is very oddly equipped. Bench seat, manual locks and windows, no rear reading lights.....but it has alloy wheels. Then there is this: That cluster must be from a pre-production vehicle, as the tach was never red like that on any of the production ones. My old 88 Regal was a November 87 build, and the tach was green like the rest of the cluster.
