  1. Black92GS
    Black92GS
      8
      146
  3. Psych0matt
      11,084
      2,648
Showing content with the highest reputation on 12/10/2025 in all areas
    L67 swap A/C
    I'm going to differ with you on this Kyle....... what OP needs is the necessary A/C piping from a 1st Gen Regal with the 3.8 engine. If you intend on keeping as much as your car is currently fitted with you'll need the a/c compressor manifold hose assembly that was fitted to the 3.8 Regal & a new rebuilt pre 94 compressor. Everything prior to 94 is R12 based, everything post 93 is R134 based. When GM introduced 134 in 94 they changed ALL of the A/C line fittings thread pitch so NOTHING from prior & post can be used together. My suggestion to you is to keep your 92 car all 92, get that old 92 3.8 manifold hose assembly & purchase a new *rebuilt* pre 94 A/C compressor, even the manifold hose assembly changed in 94 because GM redesigned the back end of the compressor housing for 94 so the old manifold hose will not attach to the newer design compressor housing. Purchase yourself a new receiver/dryer as well as a new orifice tube. Go into Rockauto, search 92 Regal, they still house most of what you'll need.
  2. pwmin
    Mystery Caliper Bracket
    I just figured it out! Got the GXP brackets and calipers from NAPA. They cut the mounting part off and drilled/tapped new mounting holes.
