Showing content with the highest reputation on 06/24/2025 in all areas
  1. Black92GS
    Sitting 1995 Regal GS
    No problem. Pay attention when ordering a replacement though, as there seems to be different part numbers based on whether the car has column or console shift, and whether it has steering wheel controls. The key fob not working is highly likely to be bad solder joints in the keyless entry module. There is a write up on here about repairing them. Extremely common issue!
  2. Black92GS
    That would be the turn signal switch. Not terribly hard to replace, but you do need to pull the airbag, the steering wheel, the clock spring and the lock plate to get to it. Sounds like the Brake shift interlock is acting up. What I can't recall is whether the turn signal switch issue that causes the left/right brake lights to not illuminate correctly also causes issues with the shift interlock not releasing like it should. I'll let someone else chime in regarding that.
  3. Black92GS
    New (returning former) member with a new to me 1st gen survivor
    Like the title says, I am a new member now, but I was a fairly regular member here around 15-20 years ago. My screen name at that time was Regal_GS_1989. I originally owned an 89 Regal GS coupe, a 92 Cutlass International Coupe, and finally a 2000 Regal Sedan. Life got busy, I stopped posting regularly, and the 2000 was sold off about 10 years ago for something newer and more family friendly. Time has marched on, and I am now in a position where I have the time and resources to be able to own a “weekend” vehicle. As luck, or possibly fate would have it, this beauty quite literally fell into my lap at the perfect moment… A 92 Regal GS Coupe. Black, Grey leather interior, low milage, One owner, garage kept its entire life, ordered new with every option box checked off…save for the sunroof. It’s truly worthy of the term survivor, and it’s exactly how I would have ordered one myself back in the day. Gotta say…it feels sort of strange to be back here posting again about a 1st gen coupe…but I can get used to that I am also surprised at how many screen names I still recognize as well!
  4. Black92GS
    It’s been just a little over a year now since I got the Regal…so what better way to celebrate that than with some more recent pictures. Nothing much visually has changed except for the refinished wheels and new tires…which was a fairly large, yet subtle change on its own. My intent is to keep the car as stock as possible, and to keep it up to snuff mechanically to be used as a reliable, fair weather cruiser. And to shake things up…. This is the final picture I ever took of my 89 GS before it was parked for good in summer of 2008.
  5. 55trucker
    Personally I'd rather look for as many needed bottles of AC DELCO ATF Type III (H) which one can still purchase today, it IS GM's designated fluid for all older transmissions that used Dexron II or Dexron III (H).
  6. Black92GS
    Also, just a bit of a warning. If a trans fluid/filter change is in the books, it might be a good idea to insist that they use dexron /mercon fluid, instead of DexVI or something like Valvoline MaxLife. You can't get licensed Dexron III these days, so the Dex/Merc fluids that state they are for older GM and Ford vehicles are going to be the closest you can get. I have a 1992 Regal that is fairly low milage (currently under 72k KMs) that still had its original trans fluid in it. It was due for a change, but otherwise everything was functioning as it should. I did a pan drop, changed the filter, and re-filled with Valvoline MaxLife. Got the levels set, and everything seemed great. In short order though, I was dealing with a downshift issue into 1st. Essentially, when the vehicle went into lockup before the trans was fully warmed up, slowing down to the point where 1st would engage resulted in the trans acing as if it were in neutral. Even the increased line pressure in manual 1st. wasn't enough to engage it. You could shift to Neutral and back into Drive though, and it would act exactly as expected, so I simply worked around it and shifted into Neutral while slowing down, then back into Drive just before coming to a stop. The more I dug into the issue, the more I realized that the MaxLife was likely the cause, as older transmissions don't necessarily play nice with the much lower viscosity of MaxLife. I just recently pumped out 4.5 quarts of trans fluid and replaced it with Dex/Merc, and on the first test drive the issue was nearly eliminated. My plan now is to drive it a little bit more, then pump it out and refill again to get as much out as possible. I will be sticking with Dex/Merc from now on for this one.
