Showing content with the highest reputation on 05/20/2025 in all areas
  1. Nas Escobar
    What can I swap into my '89 Grand Prix MEGATHREAD
    If you want to find out the real problem, you have to start by doing a compression test. An educated guess would be that your head gasket is gone, and if you're mechanically inclined, wouldn't be too hard to do on an MPFI. Now the thing is that in order to make sure it's not a piston ring or valve seal, you're going to have to also do a leakdown test when you do the compression test. That would give you a better idea to what's going on. I know someone stated you might need a new head but if you can salvage the engine, it would be the cheapest option.
  2. 1QUICKHATCH
    3400 would be the easiest swap, no need to change the harness. 3500 is a little more work than the 3400. I have some information on the swap in one of my old post approximately 6-8years ago now.
  3. 1QUICKHATCH
    3400 Swap done!
    I have the TV cable adjusted the best I can right now, 47-4800 is the best that I can do with the kick down set up that I have right now. A tune is going to be done in the next few months when the cash flow will allow. it also needs some 2.5" exhaust and the tall tires are not helping it off the line... lol
