      9,321
  2. Breakdown
      5,395
  4. mfewtrail
    mfewtrail
      5,979
Showing content with the highest reputation on 03/19/2021 in all areas
  1. carkhz316
    LS4 swap begins
    A little bit of an update: thanks to Grandpa Biden and the newest economic stimulus package, my tentative completion goals have been pushed up to this summer; if at very least have the engine in the car (but not necessarily driving around). Anyway, simply put, I'll be buying more car parts to finish things. In the meantime: I've received my Furches Performance oil pan, and have it loosely bolted to the motor. I sent the heads off to the machine shop for a once over and everything came back as good (I still have to go pick them up). Pressure washed the long block with some degreaser and aluminum brightener before teardown to try and clean it up a bit. There was still some heavy staining, so I opted to rattle-bomb the block and front cover with some cast aluminum, even know it'll never get seen by anybody except me (shrugs). Stripped the LS4 engine harness (and most of a 2000 truck harness) down for complete rewiring into Monte. I talked with Brandon at Furches Performance and opted to just one-stop shop for all my engine stuff. I'm getting his full DOD-delete package (including gaskets and hardware) in addition to a custom grind cam. This leaves me with just incidentals like hoses, fluids, etc to get at this point. Did a little bit more grinding on the motor mount to clear the output shaft. It didn't take much more and now I'm debating using it and just adding a spacer bracket to to bolt the two together, or just do a one piece motor/ trans mount. Thoughts?
  2. mfewtrail
    LQ1 CPS.
    If I were you, I would buy a multimeter(or two...one standard one, and one with a current clamp capable of reading DC amps) and a scan tool at least capable of reading engine data on those LQ1's. Both will pay for themselves many times over if you do your own diagnostic work. There's tons of documentation online these days to help you get started using either tool. If you want some recommendations for either, let me know(buying all the stuff I recommended would be far cheaper than a single dealership visit by the way).
  3. Giraffeassbitch
    New and semi inexperienced,
    Hello everyone! Long time lurker, first time having an account on any forum. I recently bought a '93 Chevy Lumina Z34, and am excited to start my work on it whenever I can. It's currently in another province, at my parents house, so I sadly won't be able to post pictures for a couple weeks. -J
  4. pwmin
    LQ1 CPS.
    It simple the check the voltage, but without a multimeter... Anyway, if it didn't change anything, probably wasn't it.
  5. GTP091
    Stainless exhaust build
    Had to build a y pipe so that set me back a day or two. Original magnaflow Y’ was to long and I coudnt make the turns into the mufflers with it. Also realized it was a merge pipe and would have been bad for flow. Still need to finish the tack and size the last two bends. Good progress though. Pipe in the right is almost at the height I want. Another 1/2” up and should be good.
