      21
  2. Amanita
      366
  3. GnatGoSplat
      9,365
  4. White93z34
      10,795
Showing content with the highest reputation on 05/21/2020 in all areas
    Draining Fuel Tank
    The Gen 2 cars have an opening in the floorpan above the tank to get access to the pump assembly. The port is in the trunk. One disconnects (quick disconnects) the pressure side line and inserts a long length of similar sized tubing fed to a container & let the pump run until the tank is near empty. Otherwise remove the vehicle fuel pump & pick one of these ....and screw on some hose to each end & chuck it into a drill & this little pump will drain the tank.
  2. mfewtrail
    Draining Fuel Tank
    If the pump works, you could remove the fuel line or the schrader valve and pump out the old fuel by energizing it. If the pump is dead, remove the tank access door and use any number of items to pump the fuel from the tank.
  3. MemphisMan
    Hello, friends!
    Welcome to the forum! "Quantic08"? Are you a Marine by chance? I'm retired Navy, so if you are, Semper Fi I currently own four cars with the 3.4 DOHC engine and three of them are running very well. The one that's not running is a car that I bought not running and haven't gotten to it yet. Two of my four cars are 5 speeds too. One is my daily driver and the other one is the one that doesn't run (yet). Again, welcome aboard!
