Showing content with the highest reputation on 11/13/2019 in all areas
    CS window trim.
    Hey everyone, I want to remove the black window trim that goes around the top/bottom sides of the rear glass and doors on the 88-93 CS International coupes. I need to remove the nice ones from my 89 parts car to use on my 91 International coupe. Are there any tricks to doing this? I obviously don't want to damage them. I'd like to remove the large piece of trim that runs between the rear glass and the quarter panel window glass also. Any ideas would be great, thank you!
    CS window trim.
    Update, I spend a lot of time this weekend finding window trim pieces for the STE and decided to tackle this same job on the International. Thank you to everyone who commented and helped out! I thought I would practice on this 95 CS coupe I found in my local yard. If I messed something up or broke a piece of trim, it wouldn't have been too big of a deal. Turns out, it was pretty easy to remove all the pieces. Now I have two sets of perfect window trim to replace the bad ones on the 91 car. So I just used a small flat screwdriver and slowly started to pry the trim away from the body. There are metal clips that hold it to the body of these cars and it took me about 10 mins on each piece as I took my time and made sure not to damage or bend them. I also removed the passenger side lower beltline trim as the window was broken and learned how to get them out. I haven't removed the upper front door window pieces as you have to get the windows down in order to remove them. The junkyard car unfortunately has bad ones on each door so I didn't mess with it. Getting back to the front door lower beltline pieces, it's the same on the STE. You have to remove part of the door panel and get the sideview mirrors off. This will reveal two screws that you need to take out for this piece of trim. Same for the back of the door, take off the plastic door hinge cover on the inside of the door frame to expose the screw that holds on the back of the trim. Then I used a non marring tool to tap it out and over the pinch weld on the door. Not too bad!
  3. 1 of 996
    jiggity76 comes through once again!
    My car has been missing this piece for as long as I and the guy before me have owned it. But today I got a "care package" in the mail from jiggity76 and inside was the moulding I have been missing and it is in WHITE. With about 20 minutes of my time disassembling and polishing, it's as close to NOS as a used piece is going to get. Now, a missing key piece to the car is in place.......
    Thank you! That's good to know. I would post this info in your thread as well, it could help others out in the future.
  5. Bake82
    CS window trim.
    Does that help? Let me know if you need anything else!
