  1. RobertISaar
    RobertISaar
      8,740
  2. 1 of 996
    1 of 996
      157
  3. Amanita
      361
  4. digitaloutsider
Showing content with the highest reputation on 06/01/2019 in all areas
    '91-93 GP coupe reviews?
    Depending on the geographical area the vehicle is coming from (as above stated) .......rust, if the car is in a salt belt rust will get into the rocker boxes, the rear bumper rebar, the rear lifting pads area at the trailing arm mount, the rear quarters (left side fuel filler reinforcement), the front suspension member locating points, rear brake lines are a weak point for rot. All of the pre 94 cars have the small brakes, those brakes are underpowered (all of the rotors are too small, the rear calipers are too small), because of the caliper slider design the rear brakes are prone to seizing due to lack of maintenance. A/C, if it's important to you 94 is the 1st year for 134a, a 93 would require an 134a upgrade, (when I did mine I replaced the r12 compressor with a 134a compressor due to the different compressor control valves used in each). Never did really like the LH0 engine, underpowered, for 93 the trans *should* be the 4T60-E, look for *no TV cable at the throttle body* to verify that. I'm sure there's more I've left out. If you want one of this year find a nice one.
