  1. Psych0matt
      11,082
  2. runt
    runt
      4,993
  3. rich_e777
      2,648
  4. digitaloutsider
Showing content with the highest reputation on 04/28/2019 in all areas
  1. pitzel
    Is there a trick?
    I took rubber fuel line and basically 'covered' the lines everywhere that they might possibly rub on the frame, particularly through the battery box area. Fixing the vacuum lines was literally the first repair I had to do on my car when I got it. I didn't find them terribly fragile, but if they rub, eventually there will be an issue.
  2. GabsOlds
    My 1995 Vert replacement thread
    Good luck, and congratulations on taking on the endeavor. I hope you are also doing the header. This is the best time to replace it. The hardest part of the job i personally encountered was installing the rear tack strip. Order a new one, because the old one will be dry and cracked, so it won't hold the staples. It has a metal channel that it is housed in, and you cannot pull it through the channel to install it. You will have to painstakingly spread the channel apart, lay the strip in it, then fold the sides back down over the strip. I did check with an automobile interior installation shop; there is no machine for drawing the tack strip through the channel. Take lots of pictures before you disassemble, AND as you go along. God speed.
    Is there a trick?
    Nope, I didn't. I was careful and it turned out great. Just had to be patient. I'm trying to get rid of the rubber hose repairs.
