  1. Imp558
    Imp558
      6,001
  2. digitaloutsider
  3. Galaxie500XL
  4. White93z34
      10,807
Showing content with the highest reputation on 03/11/2019 in all areas
  1. oldmangrimes
    Front suspension fail
    She's back on the road! After a long winter of fighting rusty bolts, I finally got her back together yesterday. I carefully drove her around the block once, and she seemed to drive and shift fine. I haven't noticed any leaks from the transmission or the brake lines. I'll try a longer drive tonight after work and see how it goes. Parts replaced: Passenger side only: Axle. Both sides: Control arms, tie rods (inner and outer), ball joints, flex brake lines. Parts saved: Fender (I straightened the bent lip). Wheel well trim and lower cladding were slightly damaged but I reinstalled them. TBD: Passenger front tire and hub. The tire held air all winter, but I need to drive at higher speeds and go around corners to evaluate the hub and tire. Total cost: About $400 including tools. Time spent: I don't want to think about it, probably 50+ hours if you count watching videos and buying tools. It doesn't sound like much, but I found ways to make the project take forever. It was my first time doing any of these jobs on any car, so it was a slow learning curve to figure out what technique to use. I often would only have two or three hours a week to work on it, so it dragged on and on. I tried to save money by using the wrong tool for the job a few times, which just ended up with wasted time and frustration until I would give up and drive to the store and buy the right tool. Once I had the right tool and the right technique, each job wasn't bad. Moral of the story: Buy the right tool!
  2. Amanita
    Wow, Good job! Glad to see you got it working again, no doubt most people would've sent it straight to the scrapyard after that sort of accident.
