I think that looks fricken sweet! Now if only you could match the steering wheel cover... (probably a bit much) Not that it matters now, but as an idea I think black with white stitching on both would look awesome.
Don’t feel bad... I was tempted myself multiple times. What can I say, maybe I’m tacky too. If you want to spice things up, get corona apple and put it in some AppleCran juice.
^This. The studs on the taillights have sorta rubber washers on them and they disintegrate with age. . When they're bad enough, you can end up with a spare tire well that accumulates a lot of water.
Presuming you have a 5 speed Lumina Z34, than you have a Getrag 284, unless it's been swapped.
Order axles for 91-93 Lumina Z34 with manual trans and you'll get the right ones.
Tip, ensure the stub shaft on the driver's side axle either stays in the trans, or you remove it from the axle BEFORE you hand it in as a core. You'll be searching for a new one and won't find it easily!
I wonder if the amp from a Bose equipped Caprice would work. Corvette wouldn't because the amp is in the radio, also Camaro (1993+) anyway, not sure about third gen.
