  1. sean1991olds
    sean1991olds
      154
  2. Imp558
    Imp558
      6,001
  3. 95LQ1VERT
    95LQ1VERT
      311
  4. vipmiller803
    vipmiller803
      550
Showing content with the highest reputation on 09/10/2018 in all areas
  1. sean1991olds
    FE3 Badge - to put it on or not?
    UPDATE: I found a nice enough (NOS) FE-3 badge (better than the one I originally bought) and put it on! I really like the look and am happy with it! I gave it the same positioning as the Oldsmobile logo on the other side. At first I thought it was "in" a bit too much but I like how that makes it stand out, and it is the same distance as the Olds text...
    3 points
  2. 95LQ1VERT
    95lq1vert's 1994 Cutlass Supreme convertible progress thread
    You were correct, lowered the window enough to put the front guide in, then rolled it back up and popped the rear guide in. Works great now! Also go my new window guide weather seal put in. Sent from my SAMSUNG-SM-G930A using Tapatalk
  3. Dark Ride
    OBD-1- 33 Code: Map Sensor or Higher Circuit
    If you've confirmed the wiring and connector look good and all the vacuum lines are good I would try that next.
    I think it looks great! Nice to hear from you again.
  5. 95LQ1VERT
    Thank you, I used Gütermann M782 extra strong polyester upholstery thread. I picked it up at JoAnn fabrics for about $4 a roll. I bought 2 rolls, but 1 is more than enough. I hand stitched a backstitch, very time consuming but should hold up for a while. Sent from my SAMSUNG-SM-G930A using Tapatalk
