  2. architect
    Shifting from Parking
  3. 94 olds vert
  4. architect
  5. Yesterday
  6. pwmin
    Actual Dyno CHARTS.
  7. Last week
  8. SuperBuick
    3X00 Performance Parts
  9. megavolt380
    TGP Trans
  10. Vegeta
    Actual Dyno CHARTS.
  11. Earlier
  12. Nothing really. Nothing of that sort is absolutely necessary for a manual swap. All that is necessary is to get rid of the trans stuff so you don't have a constant 6+ error codes and MIL light. Even that isn't really necessary as you can drive fine with no tune changes as long as the PCM is wired to think it's in D at all times. I'm going to leave fueling and timing up to a ZZP remote tune once I switch over to E85, no sense in messing with it now. Other than that, I think the F23 speed sensor is slightly off from the 4T65E as it would read 70 when I was going 73-74, so I adjusted that to match GPS speed. On a side note, I have been looking into extending the clutch master cylinder rod about 1" behind the clutch pedal as the pedal hits the firewall before it's fully pressed, so it might only be 90% released each time which I hope isn't causing extra wear.
  13. GnatGoSplat
    Luminac
  14. Vegeta
    This aged well;)
  15. 55trucker
    Luminac
  16. pwmin
  17. White93z34
    Luminac
  18. 94 olds vert
    Luminac
  19. Black92GS
  20. White93z34
  21. primergray
    Luminac
    I see it trying to give Firebird III vibes...
  22. Lukeperrin07
    What other modifications did you have to make to the tune? Any fueling/timing sorta things?
  23. I always used Permatex Die-electric Grease, which is just a silicone grease. I'm guessing whoever used Gummi Pflege doesn't frequent the forum any more. Sounds promising. Couldn't find any actual tests or comparisons. This was the closest thing I could find to a test: https://www.bimmerforums.com/forum/showthread.php?1687676-Annoying-Door-Creaks-Gummi-Pflege-Test
  24. GnatGoSplat
  25. rcLord510
    Jiggity getting a turbo first gen?!?!
  26. Black92GS
    Just my $.02....The one you enjoy driving the most is the one you keep. There is something to be said about a mechanically sorted, but less than visually perfect vehicle that you can simply jump in and drive without worry. As much as I hate to say it, any 1st Gen W that isn't a total beater is relatively rare these days. Individual rarities within that are almost irrelevant when it comes to market value of these cars and I would go for the colour combo I like better, rather than the rarer combo every single time.
  27. White93z34
    Both are pretty clean underneath. Not Southern California clean but pretty good - I have no concerns about their integrity. Obviously the black one isn't looking as hot now that it sat out side for a time. It likely won't be available till next spring at soonest as its in the very back of a pole barn and given that its October its probably well blocked in by other cars for winter storage by now. If you're interested PM me and we can take it from there. I have all sorts of parts that could be included including an engine. Its for sure not drivable without completely flushing the fuel out at minimum.
  28. jiggity76
    Ok, is the underside ok? How much would you want for the Black one?
  29. White93z34
    Just the red one. Black is still PM3. If I keep it It will be getting converted before I drive it far.
