rcLord510 started following 2g Grand Prix dash removal? and Disabling the dimming function?
? how short are you?.....
Found this, claims to be OEM and has the box to back it up. https://www.ebay.com/itm/256942446998 Although I don't remember my OEM one being that color and having a Sterling Technologies sticker on it. I wonder if you could have a more serious problem though. If you filled and bled it completely, your coolant should never fall 1/4 below the radiator neck. The light coming on when that happens would be normal and expected. When the coolant expands and contracts, it should be pulling from the reservoir and never add air to the system. Air getting into the system when everything is properly bled and sealed implies possibility of head gasket issue. You might want to pressure test or try one of those head gasket leak detectors. - Earlier
