Thank you thank you for yours and everyone’s help. It is greatly appreciated. I had no idea there was a Facebook tgp group. I will be checking that out thoroughly. Anyway here’s a picture of my old Grand Prix. It was the reason I even knew about the tgp. I thought I knew everything about gp’s at one time. But I didn’t and still don’t. 69 sj I still regret selling it.
There are 4 separate pieces per side for a total of 8 pieces for both sides of the car underneath the rocker panel or floor pan areas for structural support. I'm assuming these are the pieces or areas that you're referring too? None of them are available anymore or will be easy to find as separate pieces that can be purchased. They'll need to be fabricated or somehow swapped from a donor car that is of course not rusted or rotted. A rust free parts car or junkyard car will be your best friend here if you don't want to have someone make them.
Ric started following 1993 Cutlass convertible (rocker panel) reenforcement and 1993 Cutlass convertible (rocker panel) reenforcement
The strip I have on my '93 Cutlass convertible is rusted and bulging. Can it be replaced? How difficult is the job? Where can I buy the part? This is the way it was described to me... "The heavy-duty metal strip you are describing on your 1993 Oldsmobile Cutlass convertible is likely a structural reinforcement plate or subframe connector. These components are designed to enhance the rigidity and strength of the vehicle's frame, especially in convertible models where additional support is needed due to the lack of a fixed roof. The series of bolts hold this reinforcement plate securely in place, attaching it to the car's subframe and rocker panels. Over time, these parts can rust, particularly in older vehicles."
Thanks for your extensive input on this subject, I'll continue to follow your updates. I also just started a new question regarding rocker panel reenforcement strips for my '93 convertible. If you happen to have any thoughts on that too. Thanks again.
You're talking about the "cigarette lighter" sockets? They're supplied with power and ground, if either or both are non-functional, the socket won't work. Obtain the wiring diagram for them from the service manual set for your vehicle. I buy 'em used, from sellers on eBay.
90sEraWhips started following Detent "Kickdown" Cable replacement and 3.1 MPFI LH0 constant knock or tapping sound
chevyjoe0769 joined the community
Does anyone have the actuator nee or used in working condition for sale 24503860 part number
19Fever42 joined the community
Dom joined the community
My 12 volt plugs in my 2006 pontiac grand prix gxp are not working. I have checked fuses and they are all fine. The plug on the outside of the console doesn't work neither does the one inside? Anyone have a solution to my problem?
Getrag 284/282 SS braided clutch hydrualics/bleeding procedure.
Mach 5 replied to 19Cutlass94's topic in FAQs and Technical Information
Hey Jay! over 11 years later I am still using your write up! links all still work! Thanks! -Jarek -
That’s exactly what I was thinking, find a jy car with it and pull it along with the pigtail, and go on all data or something to find the wiring diagram. Unfortunately, coming across a 97-00 car in any jy within 100 miles of me is difficult, let alone one that came with ecc
First off thank you. That GTP is like my baby lol If you manage to connect the ECC to the proper wires it should work. I don't know exactly what wires are what in these cars for the climate control units. Mine shows outside temp and whatever temp I set the dials to. I would probably go to a junkyard and grab as much wiring harness from a car that has ECC and start figuring out where all those go so you can tap into the correct wires.
First of all beautiful gtp!! Second of all I did a comparison and the only difference between the 2 is 1. It shows inside temp and outside temp on the ecc and doesn’t on mine obviously(no screen) and 2 it has a little different button selection and it automatically adjusts the fans like you said, however since that is done in the unit, I’m wondering if(because I’m guessing mine also has at least the inside temp sensor) that if i connect solder on the connecter for the ecc and confirm that I’ve made the right connections with schematics, in theory everything should work the same, I’m really hoping at least…
I’ve seen that one before, I’m not totally sure of the difference between automatic and manual control, I know one has 3 knobs and my version has 2 knobs and 2 sliders, im not sure which is which
I know doing this isn't easy. I found a thread from the old grand prix forums that may be of use. I do like the electric climate control feature in my 2000 GTP. https://www.grandprixforums.com/how-to-write-ups-tech-tips/106563-97-02-pontiac-grand-prix-manual-dual-hvac-to-automatic-hvac-conversion.html
rcLord510 started following Convert to ecc?
Have a 03 gtp and Im interested in trying to convert it to have electronic climate control, since I believe that option was removed in 00, does anyone have any pictures of behind their dash and the connecter that it uses, along with maybe some schematics, I know it’s possible, just wanna know how challenging it’d be
On the TGP facebook group find these 2 people Matt Shantz to buy a rebuilt crossover Adam Perkins for your ECM chip These are the only people who do that for the TGP community with the experience you'd want.
06 Buick Lacrosse 3.8L Surging/Bouncing RPMs when accelerating lightly
th0mathy posted a topic in Powertrain
I've got an issue with my 2006 Buick LaCrosse where the RPM's surge anywhere between 1800 and 2200 RPMs. Sometimes the bounce will be +/- 100, while other times the engine will bounce a bit more aggressively, likely +/- 200 to 300 RPMs. As soon as I let off or put more pressure on the pedal, the issue disappears. This issue began almost immediately after I replaced my Air Filter, but I've checked it 1000 times to make sure it's the right size and that it's seated properly. I've even replaced it with another filter, but it didn't stop. Now, I'm aware similar posts have been made, but the solutions I've found haven't worked. I cleaned my MAF, cleaned my EGR, replaced my Throttle Body, bought new spark plugs and wires, and tried a vacuum leak test with a can of Carb Cleaner, and nothing has shown up to be a problem. Another thing that makes my problem unique is that this issue will stop sometimes, mostly after I disconnect the battery for a few hours. However, it'll start back up again after a few weeks of it driving completely normal. This is the part that has really stumped me. As for data on my scan tool, the only thing I've identified that may be an issue is that my Fuel Trim seems to always be negative. It seems to be -5 at idle, and between -10 to -15 when driving. I'm not sure what's causing this, but I have no check engine lights indicating that there's any type of fuel problem. I've also checked my mass airflow sensor data, and it seems to be reading as you'd expect, but the data does bounce up and down when the engine and RPMs do. Otherwise, the data seems completely normal. I'm no mechanic, so there could be valuable data I'm missing, and I'd happily upload my data if someone here is willing to look at it. I've been left completely stumped by this issue, and it seems to be becoming slowly more frequent as time does on. I'm not sure what my next step should be, and I'd greatly appreciate some help here -
th0mathy joined the community
GM manual diagrams for rear alignment.
55trucker replied to jiggity76's topic in Brakes/Suspension/Steering/Wheels/Tires
Any alignment shop will have the cars specs programmed into the racks electronic head unit. That shouldn't be an issue. -
Ha! I knew there was something I was forgetting. Yes in fact there is indeed an update... Ive not seen any differences in the carpets other than the rear area I posted earlier about. Ive got the convertible carpet removed completely and have been deep cleaning. I dont see any structural differences in the floor pan layout between the coupe and convertible until you get to just behind the rear seats. Life events are holding me up ordering the carpets right now. But when I do I personally will be ordering two identical slate grey carpets from RockAuto for a 1994 Cutlass Supreme and trimming one to fit my 1995 convertible.
Can't get the steering wheel controls to work with the Pac Swi-X controller
Nick727 replied to Dark Ride's topic in Car Audio
Thanks I really appreciate the update. Just keep me posted. Thanks again. -
jiggity76 replied to jiggity76's topic in Brakes/Suspension/Steering/Wheels/Tires
So...what should I do here guys come alignment time at a shop? Take all this info with me? Do you think they'll have specs saved in their system for our cars? -
You noticed that was well.... in my 91 service manual the *service checking* angle is +.10 (or) 1/10 degree positive ...plus or minus .5 (or) 1/2 degree service setting is + .5 degree...plus or minus .5 degree
