Flaring and making lines in no issue. I have benders and a hydraulic flaring tool which makes making lines a breeze. If I have enough line, I'd just bend and reattach, but I may make some unions otherwise. I know GM likes to make oddball thread and line sizes at the MC, so no surprise there. -
55trucker started following Monte Carlo Z34 brake master cylinder options/ ABS delete?
55trucker replied to carkhz316's topic in Brakes/Suspension/Steering/Wheels/Tires
Being an ABS VI you will have to either re-bend the existing lines at the current ABS module to fit into the 4 ports of the non ABS master or add extensions onto what's there. What's not known is if what is there right now will have the same 4 different line nut fittings that the non ABS master makes use of. Each line nut that goes into the appropriate master port has a different thread pitch & diameter so they could not be mixed up. -
Disc all around. -
Do you have drums still in the back? - Yesterday
carkhz316 posted a topic in Brakes/Suspension/Steering/Wheels/Tires
As the title states, I'm looking for any/ all info in regards to the proper master cylinder needed for ABS deletion. I'm only wanting/ needing to do it in order to fit turbocharger piping in the engine bay, and not because of some naive safety circumvention. I am already running a smaller first gen brake booster found on the manual transmission cars if this matters. While searching RockAuto, there seems to be a lot of overlap between the 1st gen W-bodies through 1.5, with and without disc brakes, etc. So, I figured I'd ask the experts since I've seen brake systems discussed here in the past. Thanks! -
rcLord510 reacted to a post in a topic:
"Automatic shoulder belts" -
Would you happen to have the "Specs" the shop used, that could be taken to another shop (local to me in this case)? Thank you! -
Gotta love that quality 80s GM fit and finish! And that Regal is very oddly equipped. Bench seat, manual locks and windows, no rear reading lights.....but it has alloy wheels. Then there is this: That cluster must be from a pre-production vehicle, as the tach was never red like that on any of the production ones. My old 88 Regal was a November 87 build, and the tach was green like the rest of the cluster. -
94 olds vert replied to miltonv81's topic in Cutlass Supreme Convertible
I had a similar problem on a 2010 GMC sierra. The drivers side door window would only operate when the door was open. I dug into the wiring and found a wire that was nearly broken. I would check wiring and grounds. -
miltonv81 started following 1994 cutlass convertible windows
Here's me issue. Alternator died and the windows and top quit working along with all the guages. Replaced alternator, guages are back working but the windows now when you turn the key on they will work sometimes and sometimes not in conjunction with the top. Open the door when they are working all is fine till you close the door past the second detent then they quit working. Initially thought it was the circuit breaker and that is assuming the same breaker controls the windows and top. Now thinking the connector for the door to body but I wouldn't think the the wiring for the top would go through that connector, no sure. any body ever experience this?
rcLord510 started following Sitting 1995 Regal GS
