So nope the low coolant light is still on. I thought repairing the broken wire would help. Not related at all I guess. I would like to find an nos gm oem sensor. Just so expensive and it probably won’t fix the issue. You could have just a 1/4 of coolant below the radiator neck and the light goes on. When I top if off in the radiator it goes off. It seems to only go on when I service the cooling system and have to bleed all the air out of the system. -
