Bounces when driving slow.
55trucker replied to Q-Ball's topic in Brakes/Suspension/Steering/Wheels/Tires
Time to lock the front door.........lol anyone who wants to get in has to answer a skill testing question 1st -
Hi guys, I'm still alive and well and still have dome light switches! The site used to send me an email when someone posted on this thread, not sure if that doesn't work anymore? My direct email is mezz@benris.com if anyone else is still looking or switches.
55trucker started following The Rental and Bounces when driving slow.
Spammer...... -
garrenhart replied to Q-Ball's topic in Brakes/Suspension/Steering/Wheels/Tires
That low-speed bouncing can be tricky to diagnose since most suspension setups react differently at slower speeds. Sometimes, even after new shocks, tires, and alignment, small imperfections in the suspension bushings or worn mounts can create that “bouncy” feeling at 15–20 MPH while disappearing at higher speeds. Checking for uneven tire wear or slightly loose components can help pinpoint it. For anyone learning to manage these subtleties while driving, places like Scuola Guida Keller in Locarno and Bellinzona offer practical guidance on handling vehicles safely under all conditions, which can make noticing and correcting these issues much easier. Routine inspection by a trusted mechanic focusing on suspension links and mounts often resolves the problem, rather than repeatedly swapping tires or shocks. -
garrenhart joined the community - Yesterday
The Rental
The Rental
LOWSLOWGP started following jiggity76
LOWSLOWGP started following SuperBuick
55trucker started following 96 wheel bearing/hub
Black92GS replied to Andrew T's topic in Brakes/Suspension/Steering/Wheels/Tires
That sounds about right. The SL was the top tier cutlass trim in 1996, but GM being GM....you could spec up a base model to be more loaded than the top trim level, or you could delete enough from an upper level trim to make it less equipped than a base. In some cases, features exist on some vehicles that don't even show as being available for that make/model/trim/year combo. I think it got slightly better as the years progressed....but it still exists to some extent today. -
Interesting. Oldsmobile always had some unique ways of going about option combinations and designations. Thank you ps The ABS light has gone out but did come back on. A scan and physical check at the shop comes up everything is ok. Has been some very low temps and a recent snow storm where I am, for now I'm going hold off on any replacement as it may be just weather related. -
I think in 1996 it was just Base and SL on the Cutlass Supreme. But admittedly I'm no expert on that. Cutlass trim was odd there were higher tier ones that were oddly stripped and base ones that were oddly loaded. Generally speaking it meant leather, sunroof, dual zone electronic climate control, and variable assist power steering. Sometimes you'd get the 3.4 DOHC v6. Someone else will correct me, I'm sure. -
Yes, pardon. So there was a base and SL level trim, or was anything above base a SL? Sorry for the added questions, just trying to learn more about the car. -
You mean SL? It's just a trim level. -
55.. and White..., Thanks for the speedy response and information! Still a bit curious, what is the LS option? -
not even a difference ABS/non abs on the gen1 front knuckles. the sensor is separate of the wheel hub - why gm couldn't have continued this into the later cars is beyond me. buy whichever brand you determine to be the highest quality or fits within your budget -
No difference to be had..... for the part # go to Rockauto.......search your vehicle, the hubs are a generalized item, there is no specific item for a premium vs basic car series, just ABS vs no ABS -
Andrew T started following 96 wheel bearing/hub
Looking to replace the the front (driver side I believe) wheel bearing/hub on my 1996 Cutlass 2 door base model. It appears there is a SL also but that the part is the same across the line. Can someone provide a part number and advise as to the SL difference, if any? Thanks
Welcome. -
Pollk joined the community -
Welcome aboard!
Viktor joined the community -
