Showing content with the highest reputation on 05/30/2026 in all areas
  1. Go4DaMo
    Wheel fit
    I would think bolt-on spacer adaptors would be simpler than replacing 20 studs.
  2. Black92GS
    1st Gen W body 14" wheels?
    My 88 Regal had 14inch alloys from the factory, and the steel wheels I used to run my winter tires on were 14 inch as well...which I believe were originally from an 88 ish Lesabre. Still have those winter tires and wheels kicking around, and had them on the GS last winter for storage while the alloys were out being refinished. They fit without issue. I just automatically assumed they would fit any 88-93 1st gen with factory brakes. Brake Rotors on RockAuto start showing some different fitments for 94+ cars...with some showing they fit 88-96 models, and others showing that they only fit 94-96. Not sure if that's incorrect....or if so some of models/trims started getting the larger 1.5 gen setup up front at some point. So 14 inch wheels on 1st gens is something I was definitely aware of!
  3. architect
    Shifting from Parking
    No shift release and rocking doesn't help.
  4. Black92GS
    Whats the point of these strut “wings”?
    Apparently It’s called a spring plate. If I’m seeing things correctly, it seems like it’s used to attach to lower part of a spring compressor.
  5. Schurkey
    Power steering whine
    The noisy PS on my Trailblazer was instantly cured when I removed the original PS fluid, and installed GM "Cold Climate" PS fluid. https://www.amazon.com/ACDelco-10-5044-Climate-Power-Steering/dp/B007Q10PTW/ref=sr_1_2?crid=3OA5JDE3131IX&dchild=1&keywords=cold+climate+power+steering+fluid&qid=1584159184&sprefix=Cold+climate%2Caps%2C239&sr=8-2
  6. 06goat75
    Trans fluid? Is that what it had in it from the factory?
  7. 55trucker
    What did you pour in for p/s fluid?
  8. 55trucker
    I very recently came across some info I was never aware of..... How many of you who have owned a Lumina (base model?) were aware that a 1st gen Lumina could be had with 14" wheels? I was always under the impression 15" wheels were the base wheel diameter....... and will a 14" wheel clear the front calipers?
  9. 55trucker
    LOL.......so there wasn't any residual trans fluid at all?
