  1. Raffaelli
    Raffaelli
      9
      185
  2. Black92GS
    Black92GS
      146
  3. digitaloutsider
Showing content with the highest reputation on 04/02/2026 in all areas
    3100 EGR delete without check engine light.
    Short answer, not really. Long answer, yes but I'm not nearly smart enough for that and I think the number of people that mess with the 94/95 ECMs is in the single digits.
  2. RobertISaar
    ECM swap?
    VATS does not care about VINs. in fact, it has no way of determining what the VIN is that's stored in the PCM since it doesn't communicate at all, it only acts based on inputs.
  3. Addicted to eaton
    ECM swap?
    Vats control Box is under the passenger side dash, By the airbag, mounted on the re-inforcment bar.. let me try and find a pic.. Top right By where the air-bag would be. I know this is the v-tas because i forgot to plug it back in when i did my wiring harness swap for hud and dic...
  4. Crazy K
    OBD2 conversion
    yes. a 93 W with a 3.1 is OBD 1 and has the electonic tranny... so do the 91-93 3.4 cars
  5. digitaloutsider
    OBD2 conversion
    A junkyard. OldSkoolGP just converted his GP over to OBD-II. You may want to get in touch with him for any advice or tips.
  6. 19Cutlass94
    OBD2 conversion
    For a conversion, youll need an OBDII wiring harness, all the extra sensors, the ports, computer. Sounds MUCH easier than it really is...
  7. digitaloutsider
    OBD2 conversion
    I'd take OBD-II over megasquirt. MS is really more of a hobbyist thing.. I wouldn't put it into something I drove every day.
  8. Psych0matt
    I had the GTP programmed to ignore it, but then I didn't delete it, so I had it added back in as stock
