Showing content with the highest reputation on 03/18/2026 in all areas
  1. GnatGoSplat
    Should I go back to stock?
    Well, that's not fun. Got all the aftermarket audio equipment pulled. Plugged in the factory radio and... sounds distorted on the left channel, right channel completely out. Pop sounds when I push the buttons. It worked fine when pulled 32-years ago, so I'm guessing something that ages has gone bad. Probably electrolytic capacitors. I've read there are some green ones that like to go bad and leak. I just learned today the amp/radio module is the same as used in GMT400 pickups. I guess that explains why these radios are modular and can be taken apart into smaller modules. Vehicles with the split radios used the same modules with cables connecting them.
  2. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
    Now in that same spot I see a coolant leak . Very small but it's there. I will be trying out some bar-seal stop leak on it in the hope this will stop it. Something else that's odd is, I had them change out the LOW COOLANT sensor for a new one, and the LOW COOLANT warning still went on anyway. The car is not low on coolant. Geez.
